Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
AD1865N-K nos DIY
AD1865N-K nos DIY
Old 31st December 2004, 06:14 AM   #1
xiaolong is offline xiaolong  China
xiaolong's Avatar
Send a message via MSN to xiaolong
Default AD1865N-K nos DIY
Happy new year.
Year-end DIY work
www.audio-sz.com
http://www.audio-sz.com/UploadFile/2...1194429342.jpg
Old 31st December 2004, 06:20 AM   #2
xiaolong's Avatar
Default NEXT
Electric circuit is this,
http://www.ptsoundlab.com/secnumeriq...eroad1865n.htm
But this electric circuit contain mistake, just pass by to correct, the work is good
www.audio-sz.com
Old 31st December 2004, 06:24 AM   #3
xiaolong's Avatar
Its voice I had to contrasted the PCM63/ PCM1704/ PCM1798.
It is outstanding, in these DACs it express the most balanced
www.audio-sz.com
Old 31st December 2004, 06:38 AM   #4
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
simple and neat happy new year!
Z
Old 31st December 2004, 10:58 AM   #5
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: NEXT
I just had a look. The Analog stage shown IMHO is not particulary suited to the AD1865 and worse, it actually requires a modification to work well for non-oversampling DAC's.
I originally concieved this circuit for modifications on the Philips CD720/21/22/23 and related (Philips CD71X and Marantz CD3000/4000 & CD36/46 et al) which are equipped with a TDA1545 DAC chip which requires it's output to be held at around 3V DC offset.
The AD1865 is unlikely to be too fond of 3V DC offset on the output.
The rest appears to be basically the Audio Note DAC Kit, re-drawn.
Sayonara
Old 31st December 2004, 12:17 PM   #6
Elso Kwak is offline Elso Kwak  Philippines
Banned
Send a message via Yahoo to Elso Kwak
Default Re: Re: NEXT
Sayonara
The power supply is different.
Salut.
Old 31st December 2004, 01:46 PM   #7
philbyx is offline philbyx  France
philbyx's Avatar
Hello
On this schematic, I can't understand the purpose of the NOR gates.
Some one can explain ?
Obviously, inverter are needed for LL and LR, but for me it's all.
Kuei Yang Wang :
I don't understand when you speak about offset. The analog part is only a second order filter, just after the 270 Ohms I/V converter.
Please, can you explain ?
Philippe
Old 31st December 2004, 01:52 PM   #8
Banned
Originally posted by philbyx
Hello
Kuei Yang Wang :
Pease, can you explain ?
Philippe
Hi Philippe., I guess it is kind of zeros stuffing thing with the 74HC02.
I don't feel called for to figure it out.
It also works with a 74HC04 (only one inverter used ) for the latch of one of the stereo channels. Been there done that.
Old 31st December 2004, 02:02 PM   #9
philbyx's Avatar
Hi Elso
The 74hc02 figures also on the audio note shematic... But I agree with you, a 74HC04 is quite sufficient (only one inverter as you say, Elso).
Philippe (I wish everybody a nice new year's eve!!!)
Old 31st December 2004, 02:42 PM   #10
Konnichiwa,
On this schematic, I can't understand the purpose of the NOR gates. Some one can explain ?
This is swiped straight from the AN Schematic. It does a bit more then merely inverting LE/Wordclock. One drawing error I noticed is that the line that should conncet to sdata connects to verf...
I am refering to the Valve based IV/LPF schematic further down, which BTW is a bit cheeky, as it marked ptsoundlabs and no credit is given to the source....
Basically this one:
It is designed to have ~3V on the first ECC88 cathode to match the TDA1545. The LPF Capacitor/Resistor Values are only applicable to Oversampling circuits, for non-oversampling they need to be changed to offset the Sin(X)/(X) rolloff.
If one wanted to use a similar circuit for DAC's that expect 0V DC on the output one should replace the cathode resistor by a CCS and apply (probably servo based) offset nulling to the grid.
Sayonara
AD1865N-K nos DIYHide this!Advertise here!
Ad1865n-k MONTEFIORE Swap Meet 1 17th June 2007 02:29 PM
Fs: Ad1865n-k vadimgal Swap Meet 1 20th February 2007 04:03 PM
Fs: Ad1865n-k vadimgal Swap Meet 0 10th January 2007 07:48 PM
Fs: AD1865N-K CKW Swap Meet 0 19th January 2005 11:43 AM
AD1865N-J vs AD1865N-K bambadoo Digital Source 4 6th September 2004 06:56 PM
Copyright ©1999-2017 diyAudio
