Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Luxman d-105u, upgraded opamp
Old 28th December 2004, 02:51 PM   #1
pat allen is offline pat allen  Canada
pat allen's Avatar
Default Luxman d-105u, upgraded opamp
Hi, i am new to this board, i have done some modifications into my Luxman tube cd player.
I have replaced the op amp of the I/V stage with a discrete components op amp, all FET.
I hope the picture will go thru...
I have added another board as well to control some functions via a Sony remote, because the luxamn remote seems to be a ghost.
Anyway, my power amp is a Sony ES so it is just logical to have only one remote for the whole sound system, isnt?
Old 28th December 2004, 05:15 PM   #2
pat allen's Avatar
And here is the board for the IR remote, sony protocol.
The board control 7 functions of the cd player. I do have the complete service manual of this CD player as well. If one want help i can send scan.
On the picture, you can barely see one of the op amp replacement boards.
I have also changed the muting output of this cd player. I would realy like to understand why one implement expensive tube and double dac on a cd player, but finishes it with cheap transistor muting system. It does realy clip the sound output and makes high transistions audible and realy bad. Now it is simple reed relays.
cheers !
Pat Allen
Old 29th December 2004, 03:10 PM   #3
markp is offline markp  United States
Default Re: Luxman d-105u, upgraded opamp
Are those tantalum caps on the board? I hope not!
If it sounds good... it is good!
Old 29th December 2004, 08:33 PM   #4
pat allen's Avatar
Why?
All the caps into the circuit are for dc filtering of the power supply, none of the audio path goes thru any caps in this design.
As you said, if its sounds good, it is good
I know someone that have deleted the I/V stage, and have changed the way the tubes are biased, by the help of a software simulator. He said that it sounded far better.
Who knows...
Pat Allen
Old 30th December 2004, 11:13 PM   #5
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Maybe because tantalum caps are famous for breaking down when used directly on the supply lines...
Or because they generally sound worse ( but measure better )than normal electrolytic caps...
Or ( last but not least ) the environmental and socials aspects that come around with the winning of tantalum....
http://www.interesting-information.c.../ethicsq1.html
http://www.science.uwaterloo.ca/earth/waton/s0110.html
It's only audio. Member of the non modular PCB design committee
Luxman d-105u, upgraded opampHide this!Advertise here!
Luxman LV-105u replacing outputs help! rinsbag Solid State 30 4th February 2017 09:39 AM
Luxman D-105u Transport Identification fxbill Digital Source 43 23rd March 2008 10:16 AM
Can this be Upgraded? normalicy Car Audio 0 23rd January 2008 05:20 AM
Help : Luxman D-105u service manual persuse Digital Source 7 30th October 2007 03:53 PM
WTB- PAS-3 Upgraded or Mod PC-5 and PC-6 Pyre Swap Meet 0 6th July 2006 05:20 PM
Copyright ©1999-2017 diyAudio
