Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
merry Christmas. I need help!!!!!!
Old 25th December 2004, 07:47 PM   #1
tube-lover is offline tube-lover  Hong Kong
Talking merry Christmas. I need help!!!!!!
Dear all,
Today I received sample from japan's friend & he advise me use this type of resisters used in my Version II TDA1541a Non-oversampling DAC. He said this precision rersisters was very good in digital circuit. My Version I 1541a kit was used Dale in the digital circuit. My friend said he can offer a good price to me for the 5/1000 tor & 25ppm model.
pls click the website.
http://www.koaproducts.com/english/index_02.htm
model which I prepare used in my DAC Version II.
http://www.koaproducts.com/pdf/090-091-MFP.pdf
http://www.koaproducts.com/pdf/088-089-MF.pdf
The brown one in the photo was 5/1000 tor, blue one is 1/100 tor.
I hadn't any experience for this resisters.
pls advise
thx
thomas
Old 25th December 2004, 08:59 PM   #2
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
What's the question?
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 25th December 2004, 09:20 PM   #3
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
He wants to know which color is best. It's a shame they don't offer red ones which are my preference.
Old 25th December 2004, 09:28 PM   #4
dear janneman ,
do U had any experience using this brand resisters??
Do U know the performance about this brand resisters??
my previous kit use dale metal film resisters, all 1% tor & 50~100PPM. But this brand was 5/1000 tor & 25PPM.
Better Spec than dale but performance?????? I don't know, so I ask diyers to help me. Hope can get some advise!
Japan suggest the I/V use carbon film & digital circuit use this type rersisters.
thx
thomas
Old 25th December 2004, 09:47 PM   #5
jan.didden's Avatar
Well, you must understand that I am a typical sceptic about "this resistor sounds best" or "this cap should have the plastic jacket removed to sound best".
There are so many components in a typical equipment that I find it very hard to believe that changing a few to other types will be audible (exceptions below). As can be read on various places on this board, there are many, many factors determining the perceived audio quality of a piece of equipment *other* than the sound itself. To mention a few: size, color, weight, price paid, your friends opinion, your expectations, etc.
On the case of resistors, unless you have a special piece of equipment, 2% tol should suffice. Every competently designed amplifier should be able to function according to spec with small variations in components. For example, transistor gain often varies over more than a factor of two. There are some exceptions: sometimes you need a specific ratio in a design to set a current gain or something. In such cases you may need two resistors with a certain ratio, and it is easiest just to get two .1% ones. But other than that, the tol (within reason) has no bearing on sound quality.
Resistors DO vary in noise between types. Again, the designer should take care that the amp doesn't need some unreasonable low noise resistors. Still, in input- and feedback resistors, for example, especially when higher that say 5k or so, low noise types *may* lower the measurable and ausible (ear-in-speaker) noise. Finally, resistors should be reasonably stable, for instance not change more than say 1% over 50 degrees temp change, which I think comes out to 200ppm/degree or something.
In analog stages, the resistor noise for example can directly turn up in the analog signal. I have no idea how this could ever happen in digital circuits. Digital circuits are known for the lack of resistors. I don't know to which digital circuits your friend refers to.
So, my answer would be: no, I have no experience with these specific resistors. But.... see above.
Jan Didden
Old 25th December 2004, 09:50 PM   #6
pburke is offline pburke  Germany
for a high grade resistor, I generally use these:
http://www.texascomponents.com/Tx2352a.pdf
but that may be out of the price range for your kit. They may have decent volume pricing, but you're still looking at a few dollars a piece.
don't know anything about the brand you're asking about.
Peter
Old 26th December 2004, 08:05 AM   #7
Dear janneman & pburke,
thanks for your opinions & share experience to me.
BTW, How about the precision series of philips.
This type of resistors will be very good in the I/V resistors of the DAC. Per DAC only use 2 pcs, I think will acceptable for them although in high price.
but, dear Pburke, do U compare the performance for
http://www.texascomponents.com/Tx2352a.pdf, vishay & caddock????
thx
thomas
Old 27th December 2004, 03:21 AM   #8
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
merry Christmas. I need help!!!!!! Send a message via AIM to Peter Daniel
I think for I/V conversion your best bet would be Riken or Caddock TF020.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th December 2004, 09:33 AM   #9
Dear peter,
If I choose Koa Low ppm, 5/1000 inthe digital circuit & use Riken ( RMA or RMG ) in the I/V. Will be be the better choice?
any more advise ? peter!
thx
thomas
Old 27th December 2004, 03:07 PM   #10
I don't have any experience with KOA resistors and they were not much mentioned on a forum either: http://www.diyaudio.com/forums/searc...der=descending
But Rikens work well in I/V stage (both with TDA1543 and in your circuit)
www.audiosector.com
merry Christmas. I need help!!!!!!Hide this!Advertise here!
Merry Christmas to you all. ashok Everything Else 18 25th December 2007 12:31 PM
Merry...Merry Christmas Folks... mikeks Solid State 15 26th December 2006 03:04 PM
Merry Christmas Doug Everything Else 13 26th December 2003 02:04 AM
Merry Christmas Philo Everything Else 1 7th December 2002 07:31 AM
