Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd November 2005, 09:44 AM   #81
hwb is offline hwb  Germany
Hello fmak,
this is exactly the way my modded DV-575 is working.
I am doing an upsampling to 96k with a CS8421, no matter what the input signal is. This saves me from the need for additional logic and gives me exactly the sample rate my D/A is using. The only drawback is that the current version doesn't support 192k as input.
Regrettably I'm a bit short of time this week, if you're interested we can discuss this later.
And Charly, thank you very much for the inspiration of modding the DV-575!
Holger
Old 2nd November 2005, 01:21 PM   #82
oehlrich's Avatar
I would like to do something else; enable the full use of my 192k dac by upsampling at all times with the AD1896 to 176.4 or 192k.
Hello fmak, what you want is impossible!
The AD1896 runs in master mode and in this mode the highest output rate that could be achieved is 96KHz. This depends on the maximum clock input of 30Mhz which means a maximum output rate of 117187,5 KHz.
This means upsampling is only possible up to 96kHz with the AD1896 :-((
The only chance to get 192kHz out of the AD1896 is to let it run in slave mode. This means you have to supply LRCLK and BCLK into the AD1896. Therefore major changes on the board have to be done (e.g. an additional generator creating LRCKL and BCLK from an external clock generator) which is not possible with this board.
But why upsample so high? You can’t get more information out of a low frequency signal by upsampling.
For best results keep audio in the digital domain as long as possible
http://freerider.dyndns.org
Old 2nd November 2005, 02:36 PM   #83
My own experience is that upsampling to 176.4 and 192 with 44.1 and 48k material is very beficial to sonics. This is based on my dCS setup where 176.4 sounds as good and natural as analogue.
Part of the reason is, I believe, the shifting of the low pass filter well beyond 44.1k. On my dCS, changing the filter slope and type makes quite a difference.
Even on a computer using Foobar, upsampling sounds better.
As the AD1896 is 192k capable, why not explore it?
Seems I have to use your board w/o AD1896 and then perhaps feed the signal into the AD 1896 EB development board from Analaog Devices. Pity.
Can you describe the sonic changes to the Pioneer DV575 using your board. The unit itself apparently doesn't sound too hot.
Old 2nd November 2005, 05:11 PM   #84
oehlrich's Avatar
You are right, the analogue outputs of the 575 are bad, and the digital output has too much audible jitter to be good.
Regarding your question…..
Well my setup is somehow different from normal setups and difficult to compare.
The digital signal from the 575A is fed digital (44.1 to 192) into a Behringer DCX2496. Originally the input of the DCX2496 is equipped with an old SRC CS8420. Not a good SRC and also not capable of 192kHz. So I looked around what to do and discovered the DAC1 from benchmark.
It has the unique ultrlock technique (pure maketing) but despite of this it is a very remarkable unit because it eliminated jitter nearly completely. I studied that ultralock technology and found out it works with an AD1896. The incoming signal can be all speed, up to 192kHz. The output samplerate for the DACs of the DAC1 is aprx. 110kHz.
Well the DCX2496 works with constant 96KHz internally. Inside my DCX2496 I installed a tentlabs clock for the D/As and a small PCB with a 192kHz receiver (CS8416) and a AD1896 like the DAC1 has http://freerider.dyndns.org/anlage/B...ut-Stage-E.htm. So I have that ultralock technology inside my DCX2496!
Connecting the 575 to this modded unit is really an experience, probable caused by the upsamped input signal and the internal reference clock (tentlab says 3ps!). Never heard that before and I am very happy with his. The result is satisfactory at all and the jitter from the 575 does not matter any more. I tested different digital wires with no audible effect. I even tested transmitting the S/PDIF via telephone lines (really bad S/PDIF signal) http://freerider.dyndns.org/anlage/telefon.htm about a long distance with no audible effect. This means ultralock really works great. I also tested some very expensive CD players digital connected to the modded DCX2496 and got no audible difference to 575A.
So your question about sonic changes I could not really answer. In my setup the result is really satisfactory and I didn’t want to miss it anymore. Also digital SACD and DVD-A is much better than 44.1 and much better than the analogue output of the 575A.
Old 3rd November 2005, 04:52 AM   #85
[QUOTE]Originally posted by oehlrich
[B]
-------------------------------------------------------------------------------------Thanks, interesting. What about a pcb for this, or is this part of the enhanced DV575 board, outputting at 96k?
The 1896EB board with 192k dac is reasonably priced and I am planning to get one to try.
Old 3rd November 2005, 07:06 AM   #86
oehlrich's Avatar
It could not be part of it because the ultralock has to be near the D/As so the player is the wrong place.
I made a board and all information about this you will find here http://freerider.dyndns.org/anlage/B...ut-Stage-E.htm . At the bottom of the page in the box you find a link to download the PCB board data.
Please give me a link to that AD1896EB board. Sounds interesting!
Old 3rd November 2005, 08:47 AM   #87
http://www.analog.com/UploadedFiles/...65AD1896EB.pdf
is where you find it. Can be bought on the web.
Old 3rd November 2005, 04:27 PM   #88
qus is offline qus  Poland
Huh? On another forum, where Carlos showed his mod to analog part of this player he claimed that 575 has great clock and there's no need to replace it. Can you explain me, what do you mean by "audible jitter"? For me, through digital out, the unit plays perfectly. I can clearly hear the soundstge and instrument placement on Checky and ECM records... :->
Old 3rd November 2005, 04:58 PM   #89
oehlrich's Avatar
Technically the 575A derives its clock signal for the audio section from a 27MHz crystal clock. 27Mhz because this clock is the reference for the video section. A crystal (no low jitter oscillator!) is already bad enough. To decrease this quality further the audio clock is derived from this 27Mhz by a PLL which adds additional jitter to the audio clock. This quite high jitter was measured and published by the German Stereoplay magazine. So far so good.
Now the whole thing starts to become interesting. The quality of what you will hear strongly depends on what will be done with this jittering digital audio signal?
- Recording it via S/PDIF at your PC the jitter will be gone completely. At playback from PC you will only hear the jitter of the PC audio clock. In general this is a clock generator with much less jitter than the 575A has. So the S/PDIF output of the PC has less jitter than the output of the 575A and in general will sound better.
- Connecting to a DAC like the DAC1 from Benchmark Media Systems which resamples the digital signal the jitter will also be gone completely. The same thing with my moded DCX2496 and its AD1896 input stage.
- Connecting the signal to a conventional DAC which regenerates the clock for its D/A chip via a PLL from the jittering input signal the amount of jitter you will hear strongly depends on the quality of the PLL inside the connected DAC. Using a DAC with a very good (maybe multistage) PLL, you will get a perfect result. Using a DAC with a weak PLL the jitter of the 575A will be audible.
So if you say your result is perfect only means you have a very good DAC with a good jitter reduction. It did not mean the digital output of the 575A has no jitter!
But be happy, you are one of the lucky guys like me who have no problem with the jitter produced by the 575A ;-))
Old 3rd November 2005, 05:21 PM   #90
Carlos often has opinions of his own. Audible jitter means that the sound isn't right.
Tweaking Pioneer DV-575A anodyne Digital Source 0 11th March 2007 05:40 PM
pioneer dv-578a mod, or how to get sacd out whodiini Digital Source 5 22nd October 2005 08:36 PM
SACD and DVD-A Digital Output Blue_Max Digital Source 2 4th December 2004 01:31 PM
Digital output format of Sony SACD Engine with CD? ThorstenL Digital Source 10 7th November 2004 12:13 PM
Page generated in 0.14445 seconds (90.39% PHP - 9.61% MySQL) with 11 queries
