Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd December 2004, 10:10 AM   #1
fallow is offline fallow  Finland
Default building dac: cs8416+cs43122
Have someone done dac with same receiver and converter. how did it sound?
Which type opertional amplifier is suitable to use at analog conditioning, I'm would prefer to use opa627 or opa227, which I have already at so-8 case.
In which way the ground layer's should be connected?
Old 30th December 2004, 06:49 AM   #2
xiaolong's Avatar
Send a message via MSN to xiaolong
Default I got two kind slices
Very and quickly do to experiment to take a look with it,
What demand do is a super and in general use DAC of version
www.audio-sz.com
Welcome everybody arrive my BBS to do the guest
www.audio-sz.com
http://www.audio-sz.com/UploadFile/2...1194429342.jpg
Old 3rd January 2005, 01:03 PM   #3
Default finished pcb
Now I finished board on DAC, please check it if I'm at rigth tracks.
first schematic
Old 3rd January 2005, 01:04 PM   #4
Top layer of pcb:
Old 3rd January 2005, 01:05 PM   #5
And bottom layer of pcb
Old 18th February 2005, 02:40 PM   #6
macsaif is offline macsaif  Slovakia
Default CS8416 fonction selection
is anybody able to tell me which mode is better for CS8416:
1. Normal phase detectorupdate rate
2. Higher Phase detector update rate
(selected by TX pin)
Can I set Emphasis Audio Match on? What does it mean? If I have CD with Emphasis it will use deempasis... if not, the deemphasis module is bypassed in CS8416?
The DAC chip I will use is CS4397.
Thank you!
Frank
Old 11th March 2006, 11:43 PM   #7
Nerull is offline Nerull  United States
Correct me if I'm wrong, but I think connecting the TX to gnd is for non-sigma delta dacs while tying it to the VL is for delta sigma dacs (refer to CS8416 datasheet, I'm pretty sure it says that somewhere in there...)
~Tom
need help, about CS43122 cubezone Digital Source 0 7th May 2007 02:41 PM
CS43122 vs. AK4395 killer DAC's peranders Digital Source 31 25th May 2005 03:35 PM
CS43122 output Prune Digital Source 7 10th February 2004 07:50 PM
Crystal CS43122 DAC Thomas Giz Digital Source 8 18th March 2003 04:56 AM
Cheap 24/96 DAC with CS43122 jwb Digital Source 62 16th November 2002 05:43 AM
Page generated in 0.09058 seconds (72.08% PHP - 27.92% MySQL) with 11 queries
