| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi there.
As i found out lately, i can get my hands on some CS8416 (as opposed to none, which is good). Now, the thing is... while looking through the 8416 datasheet i suddenly sensed an acute migrane. This thing is no 8412 i said. Damn right it's not. So how am i to proceed? I want to build some non-os dacs. Basically it will be the SPDIF (8416) receiver and then a slot in which i put whatever dac board i choose (tda 1541/43/45 etc). So i need to be able to put the 8416 in the required state, like I2S or EIAJ on the outputs, with switches. Is there please anybody there that can enlighten poor little'ol me? Some schematics won't hurt... |
#2 | |
Just had a look and it's not half as bad as that. Only read chapters 13, 14 and 5. Seems rather simple. Might even be possible to wire an adapter for it to fit in a 8412 socket. Does anyone know why this part is a lot cheaper? |
#3 |
What in the datasheet are you having trouble understanding? Section 13 gives you basically everything you need to know. The CS8416 is easy to use. Put appropriate caps on FILT, feed the signal in to RXP, get the recovered clock on RMCK and the audio data on the three output pins. You don't need to supply a separate clock (OMCK) -- it does nothing in normal operation; it only fills in if the signal lock is lost temporarily. The only thing you need to be careful about is FILT, which determines how well the device will filter jitter. Layout and parts selection tips are given in section 19. Follow that advice and you'll be fine.
#4 |
As my native language is not english & i'm not a digital guru (mostly analogic stuff) i got a little confused, mostly by the amount of data in the datasheet (most part about sotware & registers).
Believe me, it's an eye opener when somebody gives you that little hint to where the door is. I got it pretty good now. Basically i'm a little masochist about these things , so i wanted to figure it out and do it all myself as opposed to have somebody else do it for me (this was pretty simple since there wasn't anyone able to).What i wanted to do was to build this http://www.tnt-audio.com/clinica/convertusdecdig_e.html with the possibility to change the 1543 with 1545. So the problem was: 1. configuring the OLRCK & OSCLK as inputs 2. configuring the out format as I2S (for TDA1543) or EIAJ (for TDA1545) Now i'm mostly "iluminated" |
#5 |
I see.
You can safely ignore all the stuff about software and registers (about 70% of the datasheet). That's only useful if you're using a microcontroller, and you won't be. Another 10% of the datasheet is devoted to OMCK, which you can ignore as well.
#6 | |
| Changing bridge. Advise needed | Fidelity Audio | Power Supplies | 10 | 7th December 2010 12:11 PM |
| Help needed ! Inter M R300 schematics needed ! | alexclaire | Solid State | 30 | 9th September 2009 07:14 AM |
| Changing 1543 DAC from 8V to 5V. Help needed | Nielsio | Digital Source | 5 | 1st January 2009 10:01 AM |
| Ode to the 8416 | dsavitsk | Tubes / Valves | 2 | 5th March 2007 12:04 PM |
| Help needed changing from srpp5814a to srpp12bh7a | georgehifi | Tubes / Valves | 11 | 21st May 2004 07:22 AM |
| Page generated in 0.09400 seconds (79.48% PHP - 20.52% MySQL) with 10 queries |
