Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th February 2005, 09:12 AM   #11
Send a message via ICQ to mat_cauthon
Thank you very much!
I looked in the service manual and under "Mechanical Parts - CD Mechanism Unit) ist simply says "CD Mech Unit: MGCB30" and "Pick Up: KCP1H".
I did not found anything about a Sony Laser Unit.
But Iīll try to get one (or two) as fast as possible, just to have it here. And then Iīll have the Playerīs Laser checked (and maybe change the OP-Amps).
I donīt want the same thing happen to this one as it did to my CDX 1100. Itīs Laser is completely done and a new one out of sight.
So, again: Thanks!
Nils
Old 1st March 2005, 01:25 PM   #12
To find the model, don't look in the service manual, look on the pickup, there's always(With Sony KSS) a white sticker with the model clearly marked in black.
Also, I have a Sony CDP-XE300 that has the exact same skipping, fast forwarding problem.
In my case, since I have 3 Sony CDP and I use only 2, I swapped the drive(Using KSS210) from a model with a crappier UI and condition.
Someone could tell me if changing the pickup turns successful, what else, I'll have to try to change the motor and regulator, since the CD is easy to stop spinning with your finger when it starts working bad.
A very good supplier in US & Canada only unfortunately, studio sound electronics, has both the KSS210 and KSS213.
Antoine
http://dmsaudio.ca/
Old 28th December 2005, 03:15 PM   #13
had the same problem with a Yamaha CDX-920. Maybe it helps you. In the inside there are two resistors which can be adjusted. One for track and the other - I donīt know.
Take a screwdriver and try to adjust them. It took me about 3 hours, but now the player works again. I alway did it a little step when the unit was turned off.
But be careful and mark the resistors before turning them!
- Boris (spongebob-2005)
Yamaha C-80 preamp problem Moondog55 Solid State 35 14th September 2010 07:05 AM
Another Yamaha C-80 problem Moondog55 Solid State 24 20th August 2009 11:58 AM
Yamaha RX-797 problem...opinions? bmwscoot Solid State 8 14th June 2009 10:12 PM
Yamaha C-4 Muting problem Notorious Solid State 2 12th July 2008 07:03 AM
Yamaha B-1 Problem aged one Solid State 4 2nd November 2004 01:20 PM
Page generated in 0.07407 seconds (73.42% PHP - 26.58% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
