Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Help! Yamaha CDX-993 problem.
Old 20th December 2004, 07:16 PM   #1
Pete22 is offline Pete22  Sweden
Default Help! Yamaha CDX-993 problem.
Hello everyone. This is my first post here and it feels good to finally gotten around to join in after a year or two of lurking in the shadows.
I have a CDX-993 that won´t read disc´s. I changed the laser thinking that was the problem but the problem stayed. It tries to read the disc and every fifteenth attempt or so it succeed´s and the disc´s information can be seen in the window. Then if you try to press play nothing happens though.
I was looking forward to start tweaking this thing so if anyone has any idea´s it would be very much appreciated...
Peter
Sweden
Old 23rd December 2004, 09:53 PM   #2
Default Anyone?
Please help...
Old 23rd December 2004, 10:02 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
I do have some info on other CDX9XX models like the 910, 920, 930...
You should however first try to determine if these are similar machines otherwise the info will be useless.
/Hugo
Old 26th December 2004, 08:02 PM   #4
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Help! Yamaha CDX-993 problem. Help! Yamaha CDX-993 problem.
CD-platter-motor?
Did you change laser only or the whole "KSS" -mecanism?
Arne K
Don't believe everything you think...
Old 27th December 2004, 10:23 AM   #5
hjelm is offline hjelm  Sweden
hjelm's Avatar
Check all connectors between board and moving parts. Also read the RF signal with a scope if you have one.
Does the lens collide with the disc, had a yamaha that did that, this would indicate focus problems, my focus drive had major problems didnt't fix it though. Does it spin the disc properly?
Hjelm
Old 5th January 2005, 11:25 PM   #6
Hello again
Yes, i changed the whole "kss" mechanism and not just the laser. The disc spins like it should too. I don´t have a repairmanual for the model otherwise i probably could figure out where to find the rf-signal with a scope.
It would feel terrible to scrap it but i don´t know what more i can do with it.
I honestly don´t have a clue where to look next...
Old 6th January 2005, 07:40 AM   #7
DIY !
Cobra2's Avatar
Default Try here for service-manual!
http://www.schaltungsdienst.de/gb/abfrage_sql_gb.php
Player is worth fixing...or I will buy it!
Arne K
Old 6th January 2005, 06:48 PM   #8
hjelm's Avatar
Dont know if this helps any.
On an old cdx 520 there was a pin labled EFMI which i think was the signal from the laser after a gain stage. The signal was read between that pin and a pin labled G, four pins in this group where you could connect measuring equipment.
In the cdx 520 it was 2V PP and it should make a nice eye pattern if you pressed play.
Edit: And i also recomment Schaltungsdienst if you cannot find the manual anywhere else.
Hjelm
Old 7th February 2005, 11:35 AM   #9
mat_cauthon is offline mat_cauthon  Germany
Send a message via ICQ to mat_cauthon
Hello to everyone, too.
This is actually also my first post posting.
I do own the cdx 993 myself and fear, I´ll have a problem with it myself.
After working fine for months, it now (sometimes) starts to "jump" over the disc (moving fast forward), mostly at the beginning of the disc.
Could this be the laser-unit?
@cobra2 you said a few times, it uses a common sony laser. would you be so kind and tell me wich oone it is, so I can order it (just in case...).
@pete I do have the technical manual for the 993...
Nils
Germany
Old 7th February 2005, 05:13 PM   #10
DIY !
Cobra2's Avatar
Nils
Germany
And there you will read: KSS-213C
Arne K
Help! Yamaha CDX-993 problem.Hide this!Advertise here!
Yamaha C-4 Muting problem Notorious Solid State 3 15th July 2012 12:28 PM
Yamaha C-80 preamp problem Moondog55 Solid State 35 14th September 2010 07:05 AM
Another Yamaha C-80 problem Moondog55 Solid State 24 20th August 2009 11:58 AM
Yamaha RX-797 problem...opinions? bmwscoot Solid State 8 14th June 2009 10:12 PM
Yamaha B-1 Problem aged one Solid State 4 2nd November 2004 01:20 PM
Copyright ©1999-2017 diyAudio
