Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th December 2004, 01:04 PM   #1
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
Default CD: Copland CDA 266 mods / tweaks / upgrade
Have any one found info on mods / tweaks for CDA 266 or done any mods yet ?
Old 20th December 2004, 02:10 PM   #2
a few years ago i owned a 289......
it was heavely modded - but ultimately i couldn't live with it so i sold it.
if you give your player :
a new clock + supply.
black gate bgn(x) all over.
new schottky rectifiers all over.
extra trafo for the analog output.
extra trafo for the digital department.
change the dc-coupling caps for something much better - i used jensen copperfoil 6,8uF with very good results.
this will cost you alot - but your player will be completely transformed......shocking.
i now have a krell kps20i....with the same mods mentioned above.
(ecxept it's dccoupled, so no caps in series.)
let me hear how it goes.
troels
Old 20th December 2004, 04:33 PM   #3
diyAudio Moderator Emeritus
jean-paul's Avatar
Modded a 288 once. Looks nice inside but sounded dull because of the original Teac board with its shortcomings. A new clock was the biggest improvement.
I remember that one should be careful with the carbon flatcables going to the display. Very fragile.
edit: posted wrong DAC chip TDA1547, it was obviously a long time ago that I saw one
It's only audio
Old 20th December 2004, 05:54 PM   #4
yagoolar's Avatar
Originally posted by jean-paul
Modded a 288 once. Looks nice inside but sounded dull because of the original Teac DAC board with TDA1547. A new clock was the biggest improvement.
Is there really TDA1547 ? I thought it was PCM63K, but never looked inside
Old 20th December 2004, 05:58 PM   #5
relax - it's the pcm63k.........
Old 20th December 2004, 06:59 PM   #6
Actually it is 4 pcs pcm63 - k grade.
The player is really nice, but new master clock is required to make it shine.
Old 20th December 2004, 08:26 PM   #7
+ alot more - but in my experience it hasn't got the full potential to shine through........
Old 20th December 2004, 09:21 PM   #8
jean-paul's Avatar
Ahem, it had PCM63 indeed. Mixed it up because of remembering the Teac PCB. Although it was OK after the clock mod it did not have some of the qualities some much less expensive cdplayers have ( apart from $ that is ). It particularly wondered me that the standard Teac PCB was used in contrast with a nicely designed discrete output stage.
It's only audio
Old 20th December 2004, 09:24 PM   #9
Ahem
gesundheit.......
Old 20th December 2004, 09:34 PM   #10
jean-paul's Avatar
Thank you, I hope it helps against amnesia
It's only audio
Case upgrade for my NOS DAC, plus some tweaks Nielsio Digital Source 2 10th January 2009 09:56 PM
S5 K-16LS mods, tweaks? hartze11 Tubes / Valves 3 1st December 2008 05:13 AM
NAD C541i: possible tweaks and mods? Karlosak Digital Source 4 23rd November 2006 06:20 PM
Teac 1120 Mods/tweaks Zero One Digital Source 1 30th July 2006 02:01 AM
Any mods/tweaks for a Panasonic DVD S-49 mikee55 Digital Source 4 19th March 2006 07:04 AM
Page generated in 0.09159 seconds (79.58% PHP - 20.42% MySQL) with 10 queries
