Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
How to build a DAC using CS8416+AD1865N-K, with reclocking
Old 19th December 2004, 08:51 PM   #1
Tuliman is offline Tuliman  Romania
Default How to build a DAC using CS8416+AD1865N-K, with reclocking
Hello everybody,
I intend to build a DAC using the CS8416 receiver and the AD1865N-K; the problem is that i don't have that much experience with DAC's, so I can't "design" a schematic for this particullar combination; I have lots of diy dac projects others have buildt, but not in this configuration.
So, starting with an IDE CD-ROM, the CS8416 receiver, this solution for the data management part:
http://www.rockna-line.com/diy/dac/dac.htm
based on 6 74HCT164, maybe the same reclocking, with PLL1705.
...the AD1865N-K (I have 2 of those), and I'm not sure yet what to use for the reclocking???
The output, will be with AD829, or with tubes.
Thank you,
Florin
Old 19th December 2004, 09:49 PM   #2
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Hi, from what I understand abou the CS8416 is that it will look after all of your recolocking for you. As providing you get a good clean power supply for the PLL it will producew a very low jitter cignal clock just from your input data signal (it only uses the input clock signal to obtain an initial lock onto the signal's clock or when it loses a lock from the input, although I from memory you can force it to output this clock as well if you use it in software mode).
Plus, I may just be being stupid here, but what exatcly are all those 74HCT164's doing, froma first guess all they will do is to delay the input signal by some small amount right?
Old 20th December 2004, 11:26 PM   #3
josiphal is offline josiphal  Croatia
To Tuliman:
If you want DAC for CD-ROM only, try to find I2S lines inside CD-ROM and connect it direct with TDA1543. Don't know about CS8416 receiver, most people use AD1865 with CS8412.
To bigparsnip:
AD1892 output (default) format is 20-bit I2S, but AD1865 work with 18-bit MSB first (not I2S). 74HCT164's are for conversion from 20-bit I2S to 18-bit MSB first.
Josip
Old 21st December 2004, 01:00 AM   #4
rfbrw is offline rfbrw
Originally posted by josiphal
To bigparsnip:
Josip
All the formats offered by the AD1892 are MSB first and truncating 2 LSB's can be done with a lot less than 6 '164 packages. Only the first two packages are needed to turn 20bit I2S data into 18bit right-justified data.
The remaining '164 shift registers delay the left channel such that it is simultaneous with the right channel. The AD1865 is a simultaneous input device and a digital filter would normally split the data into two simultaneous channels.
Old 21st December 2004, 08:55 PM   #5
Thank you all, very usefull the info regarding the HCT164's
Ok, can I use both of the AD1865 in this project? I have seen many dac projects using multiple TDA dac chips for better performance, does this apply too to my dac chip?
Old 21st December 2004, 09:38 PM   #6
You can put them in parallel.
Old 21st December 2004, 09:43 PM   #7
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Or you can build 2 DACs with them that sound both better than a DAC with paralleled chips.....
It's only audio. Member of the non modular PCB design committee
Old 21st December 2004, 09:51 PM   #8
Better still disregard all opinions and listen for yourself.
Old 22nd December 2004, 12:35 AM   #9
finneybear is offline finneybear  United States
Or even better: Build two DACs, one for each channel, each DAC has two 1865s in parallel, then does not matter how it sounds, you will always have the bragging right. This is exactly what I plan do with the 4 PCM1794 chips I have. Hehe
Old 22nd December 2004, 01:25 AM   #10
You'll need a bit more than 4 dacs to claim bragging rights around here.
How to build a DAC using CS8416+AD1865N-K, with reclockingHide this!Advertise here!
Decoder output: how jittery, worth reclocking? And "double" reclocking hollowman Digital Source 0 17th July 2009 02:39 PM
Ad1865n-k MONTEFIORE Swap Meet 1 17th June 2007 02:29 PM
AD1865N-K nos DIY xiaolong Digital Source 59 30th December 2006 10:46 PM
Cs8416 macsaif Digital Source 0 5th July 2005 08:03 PM
AD1865N-J vs AD1865N-K bambadoo Digital Source 4 6th September 2004 06:56 PM
