Hello guys,
I know that i can distibute the clock signal inside a player or a DAC using standard NAND or NOT chips.
The problem is that usually, they are not fast enough to deliver a clean and sharp pulse to the rest of the chips.
Anyone knows a fast logic family or line driver for this?
Who says that they are not fast enough?
I see lots of jitter in your future, as I sense you plan to use too many gates.
AC logic? Have you ever heard of ground bounce? Trying running your clock through an IC of that stuff with all the gates operating. You'll be sorry.
Jocko
Jocko
Re: Who says that they are not fast enough?
Good decoupling and power distribution practice combined with a bit of common sense - eg, don't do a 10:1 fanout from an AC logic output - and you're in good shape. The Johnson/Graham "High Speed Digital Design - A Handbook of Black Magic" is an excellent reference for this kind of stuff.
The guy wanted fast clock edges, and AC will provide that. Ground bounce? that's up to the designer to minimize that.Jocko Homo said:AC logic? Have you ever heard of ground bounce? Trying running your clock through an IC of that stuff with all the gates operating. You'll be sorry.
Jocko
Re: U
YES !
Is Toshiba (Japanese company) product !
To refer to site
http://yasu-audio.com/dsix105_02.html
http://myweb.hinet.net/home1/prbstech/DSIX/DSIX-1.htm
Elso Kwak said:
Why U = unbuffered?
YES !
To refer to site
Re: Re: Who says that they are not fast enough?
the silicon designer, that is
regards
regards
- Digital Source
- Suggestions for Clock distibution
