Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th December 2004, 11:02 AM   #1
Default S/Pdif output board
Hi guys,
does anyone know about an already made DIY project, a kit, a not DIY stuff which is simply capable of accepting I2S signals (plus datas, which I think are needed) and convert them to S/Pdif output?
The practical thing would be tap it before DACs of a multichannel player in order to obtain 3 stereo s/pdif outputs.
Sorry for my ignorance in electronics!
Ciao
Michele
Old 13th December 2004, 06:15 PM   #2
SACD and DVD-A Digital Output
Old 13th December 2004, 09:44 PM   #3
Thanks, but I already knew about this mod: unluckily it's quite expansive, and some cheap player such as Pioneer DV575 perform a DSD to PCM conversion per default, so intercepting I2S signals just beforse DACs will lead to only a I2S to S/pdif conversion, being sure all datas are PCMs.
That's the reason why I'm looking for a s/odif output board only.
Ciao
Michele
Old 13th December 2004, 11:51 PM   #4
High price aside, I don't quite see what your objection to this board is. I would have thought any other board performing the same task would be similar.
Old 14th December 2004, 07:14 AM   #5
rfbrw,
the board you linked uses a processor for DSD to PCM conversion (while in my case this is not needed because it's already performed by my Pioneed DV575 per default), and this processor is used to monitor incoming signal (look at them to see if they are PCM or DSD).
I have only PCM I2S signals, so I wouldn't like to buy a so expansive device which performs a lot of operation I do not need.
Ciao
Michele
Old 16th December 2004, 05:50 PM   #6
All the general purpose SPDIF boards I've seen (all two of them) do other things as SPDIF on its own is probabaly too small a task to charge much for. It may well be a lot cheaper to build one of your own if all you want just SPDIF out.
Old 16th December 2004, 06:17 PM   #7
hifi is offline hifi  Sweden
Look at this thread using that IC there is no particular need for the outputs to be optical
Yay! MAudio Revo modded for 3 SPDIF outputs
Old 16th December 2004, 06:45 PM   #8
tiroth is offline tiroth  United States
http://www.hut.fi/~jwagner/electr/minidisc-spdif/
As you can see it is very simple.
I will be designing a PCB for this chip in the next couple weeks that has jumpers for configuring settings. My existing boards use CS8405a but I need the DIT4096 because of its 512x MCK support.
Old 16th December 2004, 08:43 PM   #9
Originally posted by Michele Spinolo
rfbrw,
If you do consider building something, have a look at the AKM EK4101A. It has 4 spdif outputs.
Old 16th December 2004, 09:08 PM   #10
44 pin LQFP ... makes it a very user friendly chip..
ADC with S/PDIF output cbriere Digital Line Level 6 9th July 2009 09:28 PM
My Cambridge 500SE, needs an output board (to replace internal DAC Board) slbender Digital Source 0 15th May 2008 01:36 AM
Cdrom s/pdif output toolkit Digital Source 0 25th April 2007 11:36 PM
Transformer for S/PDIF Output mapperlord Digital Source 1 27th January 2005 07:55 AM
Page generated in 0.09702 seconds (79.64% PHP - 20.36% MySQL) with 10 queries
