| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
All,
I am having trouble setting the gain on a Ti PGA2310 digital volume control using a basic stamp. Whether I just punch in a control word (2x8bit words L/R = 16bit lsbfirst) or count up/dwn in binary, cannot get full 255 steps. Looks like chip only has output when lsb's are 01 (1) or 11 (3). I think is wired/programmed correctly because can indivdually control channels (right =111/left=000 - as example) so, appears to have complete 16bit control code. I tried two different chips with same result. Any suggestions? - Note that audio output, etc.. works fine, just ship not accepting full range of gain settings Thanks -ALBQ |
#2 |
for the BS-II, if you set the volume on both channels as a WORD variable, use the following routine -- bring the Chip Select Pin Low, shiftout, using MSB first all 16 bits, bring the Chip Select High.
or you can use SHIFTOUT twice ifyou use 2-BYTES, once for RIGHT, once for LEFT, just don't bring the ChipSelect Pin High. Pausing to send another SHIFTOUT just holds up the clock and the PGA2310 shouldn't mind. In both cases, bring CS high after the data is sent. Make sure that you have 10k resistors from the CLK, CS and Dout pins to ground on the stamp, they don't like to float. |
#3 |
jackinnj,
Thank you for the help. Duh - had shiftout set to lsbfirst. Also, attached is code segment w/back of napkin BS2 gain formula and serial LCD output. Additionally, this is a really great sounding chip - compares very well with higher end Burr-Brown ops amps I have heard - very cool Thank you again, - ALBQ code segment: setting = abs((1 */ 8064) - (128 - abs(128 */ volume))) low 6 pause 10 shiftout 7, 8, msbfirst, [volume\8,volume\8] pause 10 high 6 serout 0,baud,[i,192, "Volume="] serout 0,baud,[i,201, "-", dec setting,".",dec1 setting,"dB"] http://mywebpages.comcast.net/gilles...-MainPage.html |
| 6C33C tube stamp | sphinx | Tubes / Valves | 4 | 6th January 2008 02:04 AM |
| PGA2310 and Basic Stamp not responding | Xlrator | Digital Source | 5 | 23rd March 2006 12:23 PM |
| Basic Stamp Forums starting up at Parallax | jackinnj | Solid State | 0 | 26th July 2004 08:12 PM |
| PGA2310 + BASIC stamp | HooRide | Digital Source | 4 | 20th April 2004 07:05 AM |
| 1394 time stamp | Akh_Ind | Digital Source | 3 | 24th November 2003 01:08 PM |
| Page generated in 0.06670 seconds (74.17% PHP - 25.83% MySQL) with 11 queries |
