Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 6th December 2004, 04:18 AM   #1
Default Determining hot/netural in ReVox B226
After changing the DAC chip in my ReVox I'm going to change the AC hook up wire in the ReVox. After opening ReVox I found that the AC wires are connected to a voltage selector PCB. However I can't tell which wire is supposed to be neutral and which one suppose to be hot. Is there any way to determine that?
Below is a picture (voltage selector is on the opposite side of the PCB)
Old 6th December 2004, 05:38 AM   #2
philbyx is offline philbyx  France
philbyx's Avatar
The standard is :
Blue = neutral
brown, red or black=the hot
Philippe
Old 6th December 2004, 02:38 PM   #3
Hmm.. I may have wired it in reverse. Let me check. Thanks!
Old 6th December 2004, 07:57 PM   #4
You can download the service manual with schematics at http://www.schori.info/b200s/smdownload.htm . It's in German.
Ray
Old 6th December 2004, 08:26 PM   #5
I looked at the manual but I can't seem to find the information on the PSU voltage selector PCB
Old 6th December 2004, 10:19 PM   #6
Lourens is offline Lourens  Europe
Looks exactly the same as the one in my Studer A727. See attached file.
BTW, I recently opened the thing to add an extra psu and guess what -- it was wired in reverse too, like your ReVox (made by Studer ) . Just a coincidence or a matter of choice?
"Cum hoc ergo propter hoc: correlation is not causation but it sure is a hint."
Old 7th December 2004, 01:00 AM   #7
Fin is offline Fin
Fin's Avatar
Default Who cares?
I don't think that manufacturers really care about this. Many CDPs only have two wires in the power cord and a two pin plug. The polarity can be reversed each time you plug it in.
Fin
Old 7th December 2004, 02:04 PM   #8
In the service manual look on pages 5/3 and 5/4 for the voltage selector PCB wiring.
Ray
Old 7th December 2004, 02:55 PM   #9
Lourens,
According to your picture I should connect hot to brown (br) and neutral to blue (bl). I think I got it reversed and will fix that.
All,
I find it hard to work with the PCB because the path is so fragile. My solder iron keeps on burning it and the PCB. Any recommendation on how to best handle this? Thanks.
Old 7th December 2004, 06:01 PM   #10
Buy a temperature controlled soldering iron. They aren't that expensive and are a big help in preventing PCB damage. Also buy a solder sucker, solder wick and a bottle of rosin (not acid) flux. Put a little flux on the joint before you apply the iron. When the solder melts hit it with the solder sucker. That should remove most of the solder. Clean up residual solder with the solder wick. When finished remove flux residue with alcohol saturated Q-tips. You can also buy flux remover in spray cans.
Ray
WTB Revox b226/225 remote propeleris Swap Meet 0 2nd July 2008 10:55 PM
Revox B226 S poynton Digital Source 2 21st January 2008 04:30 PM
ReVox B226, B226-S CD repair tip - (weak laser symptoms) Steerpike Digital Source 1 26th March 2007 07:09 PM
TDA1541A for ReVox B226 David@NY Digital Source 11 26th November 2004 02:05 PM
Revox B226 won't read CD's Zombie Digital Source 4 21st January 2004 09:39 AM
Page generated in 0.10170 seconds (76.67% PHP - 23.33% MySQL) with 11 queries
