| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi guys and gals!
i´m looking for schematics and possibly software (.hex/.asm) for PIC16F84 or similar.. what do i want it to do? *switch at least between two different inputs (..relay of course) *a power-up timer for switching on the tube powersupply (delay ~40 seconds or so..) *mute switch so there will be a count of 3-4 button inputs and about 4 outputs on the PIC any links? anybody who would like to write a program for me? -i can program the PIC myself so all i need is the proper code in hex or asm any help appreciated!!
www.joddla.net/audio/ |
#2 |
Are you only considering PICs, or other micros as well? I'm working on an AVR preamp program and would be happy to share.
#3 |
Banned
Interesting ? Got any schematic's so far ?
#4 |
thanks for reply jwb!
although PIC would be the best for me, since i already have got the programmer for PIC and a handful of 16F84´s... 8-) (is it difficult to build a programmer for AVR´s?)
#5 |
Banned
i want to keep an eye on this thread / project because id like to build one also. and p[robably buy a pre - programed pic as im a mac'y and dont use pc : O )
#6 |
I'm skilled on PIC programming, and I can write a program in ASM or C .What the PIC is suppose to do precisely ? How many input and output do you need ? NETeagle
if I like it, I just do it ! |
#7 |
hi neteagle!
what i want the pic (16F84-4) to do is this; *at power-up there should be a delay on one pin, about 30-40 seconds, for the tube powersupply or speaker switch-on if used in a power amplifier (in that way this circuit would be universal for DIY tubes, preamps or amps..) *two buttons for switching between two inputs (CD/TAPE) that is two inputs and two outputs from the pic *one button for mute or any other function i would like, one input and one output on the pic i would like to use momentary switches, so the output from the pic should change state everytime i press the button, the button should be de-bounced with 20ms or so.. i attached a simple schematic over the PIC with the buttons 8-) as you can see there would be a total count of three inputs and four outputs (it can be simplified thrue only using one button for switching between the two inputs)
#9 |
thanks mcs, you have a alot of interesting kits and parts!!
but i´m somewhat stubborn, i still want to use a pic processor, in that way i can modify the code and maybe learn myself how to write my own code someday 8-)
#10 |
Hi Mr. Triatic
I have design a simple schematics for your application .Tell me if it is ok ! @+ NETeagle
| Attempt a fix, or get it fixed ... preamp processor not quite right :( | Deaf Cat | Solid State | 2 | 17th January 2009 10:46 PM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| My ForePlay Processor Controlled Preamp | Algar_emi | Tubes / Valves | 34 | 14th December 2005 05:38 PM |
| HT Preamp-processor... | Luke123 | Digital Source | 0 | 22nd January 2004 04:54 PM |
| New Preamp, Processor, Speakers (A Culmination of several projects) | PaulHilgeman | Multi-Way | 9 | 30th June 2003 04:57 PM |
| Page generated in 0.12411 seconds (73.96% PHP - 26.04% MySQL) with 11 queries |
