| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
anybody knows what is done in this player, got 4 x PCM61 and a bunch of 74HC164 after os filter. |
#2 |
macrovision? DD/DTS?
#3 |
nope,
That's the entry model with RLS: real-time linear smoothing. http://www.diyaudio.com/forums/showt...970#post495970 Sorry for the typo, that's probably why you did not find it with search (you searched, didn't you The rest of the info is in that tread. Never seen one, only have the brochure.. edit: and forget about the claims on my own dac, found out later it did not work as i thought it did
GuidoB |
#4 | |
I can follow the traces and draw a schematic.I was thinking that maybe the logic chips will translate the data into positive and negative halfwaves, but this hardware double oversampling is interesting too. |
#5 | |
I *suppose* that it is roughly something along these lines. |
#6 |
diyAudio Moderator Emeritus
If you want it, I have the service manual ( of course
) of HD7725 with the same output stage/DACs.
It's only audio |
#7 |
Yes, I want it, please email to me.
hd7525atbeautyphoto.de |
#8 |
Hi Jean Paul,
Could you Pls. also Email me a copy of the HK "oversampling" DAC section. Cheers, John
Life shouldn’t be take it too seriously, you will not come out alive anyway… |
#9 | |
#10 |
Hi Bernhard,
"Even if it is a rubidium atomic clock, that does not necessarily mean it is low jitter" As a quick side note, the lowest phase noise atomic clock I'm aware of is the Stanford Research Systems Rubidium Frequency standard PRS10. I use one phase locked to my 2 FTS4050 Cesium Frequency standards to reduce their “short-term” phase noise – on my module its phase noise is better then -140dB @ 10MHz 10Hz offset! John
| For Sale Harman Kardon T60 Turntable / Harman Kardon Cd491 Cassette Deck | electric blue | Swap Meet | 1 | 25th August 2006 11:36 PM |
| Harman-Kardon PM 665 | sangram | Solid State | 1 | 17th May 2006 06:32 AM |
| Harman Kardon HD7525 | ManUtd | Digital Source | 0 | 7th July 2005 10:28 PM |
| Page generated in 0.10160 seconds (76.61% PHP - 23.39% MySQL) with 11 queries |
