Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 26th November 2004, 08:02 PM   #1
cedus is offline cedus  France
Default The first part of my new transport
Just a quick thread to share my happyness !
I just bought this wonderful (and working) Philips CD101 .
I plan to use it as a transport and plug it to a DAC via the I2S output.
My question is :
What do you think is the best solution :
Build a great case for the CDM1 transport or leave it in its original case ( I love the its design).
My first idea was to take the transport off its case but it is really looking great and moreover the original case is so well build and heavy I think it will be fine.
Edit : By the way guess how much I paid for it ? 11,4 euros !!!
Old 26th November 2004, 09:09 PM   #2
There's no way you could make a case that cool at home; there's even a graph of its frequency response. Leave it as it is!
Actually - you'll probably find there a several boards wired together inside. Given its age, these get a bit twitchy if you start playing inside/ moving the guts to a new case. It might never be the same again, so If it works, just enjoy it
Old 27th November 2004, 01:54 AM   #3
You are unlikely to find I2S in a machine of that vintage.It doesn't even exist in the CD104.
Old 27th November 2004, 10:00 AM   #4
That's right it doesn't exist but there are solutions.
See here :
CDM1 transport
And the cd-304 mkII use a CDM1 and a SAA7210 where you can take the I2S from so it means you can get I2S out of CDM1.
It will not be easy but this will be worth trying it to be able to plug the best ever made philips transport (CDM1) to a great DAC !
Old 27th November 2004, 11:04 AM   #5
See here :
CDM1 transport
But you don't have a CD304 MK2, you a have CD101 and that may well mean the SAA70x0/TDA1540P chipset and that is something completely different.
Old 27th November 2004, 11:23 AM   #6
Bricolo is offline Bricolo  France
Bricolo's Avatar
open it and we'll see what chips are inside
before that, we can't take any conclusion
Just remember: in theory there's no difference between theory and practice. But in practice it usually is quite a bit difference... Bob Pease
Old 28th November 2004, 08:04 PM   #7
OK !
After some digging into the forum and into the web here is what I found :
CD101 uses SAA7000 / 7010 / 7020 / 7030 chips with 2xTDA1540 (14 bits DAC)
After all my research I2S is not possible
BUT...
It seems possible to interface SAA7000 and TDA1541A
SAA7000 can output 16 bits on left channel and right channel (DLCF and DRCF) in offset binary format.
On the other hand TDA1541A accepts dual channel input (pin 3 and 4)
Everything seems great. Just have to try and hope the formats are the same ! I am betting they are because of one sentence in the TDA 1541A Specs :
"The flexible input data format allows easy interfacing with signal processing chips such as interpolation filters, error correction circuits, pulse code modulation adaptors and audio signal processors"
I am sure they made it compatible with their earlier circuits It's good to hope !
Apparently Happy Ears did succeed last year (see the url I posted earlier)
What do you think of that ?
Old 29th November 2004, 06:06 AM   #8
See post No.2. Digital output for Studer A725
Old 29th November 2004, 06:36 AM   #9
So let's try it !
My only fear was that the format would not have been in offset binary format !
Apparently according to your post it is.
I will try that and report here !
Anyway thank you all for your help
Last question : do you think the path between SAA7000 and TDA 1541A should be very short (so it means internal DAC) or it can be longer (external) ?
Old 29th November 2004, 06:30 PM   #10
You could send the signals to an external TDA1541A via a buffer but if there is enough space inside I wouldn't bother.
DIY transport w/ CDROM drive vs player as transport dw1narso Digital Source 6 2nd September 2011 05:15 AM
Need Transport Help! Apogee Digital Source 44 10th August 2009 02:26 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 05:45 AM
part# for spare part for CDM-1 wanted joe Digital Source 5 20th March 2007 07:59 AM
CD transport audionut Digital Source 3 24th September 2005 02:44 PM
Page generated in 0.10790 seconds (79.16% PHP - 20.84% MySQL) with 11 queries
