| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I am thinking of adding a separate power supply to a USB powered device. Do I have to connect the ground(i.e. 0V) of the new power supply to the ground of the supply coming from the PC ? The signal will come from the PC USB port, the power supply from the PC USB port will be severed & replaced with a external power supply. The ground of the new external power supply (the 0V) will be tied to the ground of the USB port supply. Is this OK? Thanks. Regards, Joe Ling |
#2 |
Why not use a small powered USB hub?
Regards Fin |
#3 |
Dear Fin,
Thanks for the query. Maybe it's time for me to disclose more : The USB device in question is a sound card mated to a clock conditioner (Apogee Big Ben). I want a very good quality 5V power supply to the USB sound card. My guess is that a power USB hub is not much better than the power supply from the PC. Please assist. Thanks. Regards, Joe Ling |
#4 |
Hi Joe
I'm no expert on this but would think that the PC, soundcard and external psu would need to have their grounds connected at some point in order to share the same 0V. In a CDP with separate audio/dac board and decoder board, the 0V are connected from one board to the other. This is often done using the screen of the signal cable. Does the 0V provide a screen in the USB cable? Maybe a computer guru can help.
Regards Fin |
#5 |
you have to connect the ground, of course !
just make sure your 5v supply is floating to avoid any problems (ie not connected to earth) |
#6 |
ok did a check on my USB HDD & found that the 0V reference is connected like the after picture. Used that as the basis & managed to get the whole thing to work. Please find attached some photos.
Regards, Joe Ling |
#7 |
more photos. This one is shows how the power connectes to the USB. Would actually prefer to use a box that is shielded but this this all I have lying around.
Regards, Joe Ling |
#8 |
The display of my clock conditioner showing input frequency from the PC
Regards, Joe Ling |
#9 |
My PC. I am using it as a transport (CD transport)
Regards, Joe Ling |
#10 |
more showoff pics. This is the view from behind my listening chair
Regards, Joe Ling |
| Separate power supply - Umbilical Cord | marcutan | Tubes / Valves | 39 | 27th January 2010 07:18 PM |
| separate chassis power supply | onixuser | Class D | 2 | 4th March 2005 08:42 PM |
| Holton separate power supply for imp/output! | B.I.G | Solid State | 3 | 15th February 2005 04:08 PM |
| Aelph-x separate power supply for drivers | D3 | Pass Labs | 2 | 29th January 2004 01:32 PM |
| Separate power supply chassis- with a difference! | SHiFTY | Tubes / Valves | 7 | 27th February 2003 03:32 PM |
| Page generated in 0.10250 seconds (79.27% PHP - 20.73% MySQL) with 11 queries |
