CS8420 Schematic can you double check? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 18th July 2002, 10:51 PM   #11
hifi is offline hifi  Sweden
it not the zip it was the computer that wasnt up to it i have drawed it in photoshop.
/micke
Old 19th July 2002, 04:24 AM   #12
The extractor reports there are no files to extract. Did you have a file name extension on the file you created? Is it a Photoshop PSD file, or did you save to a jpeg?
Anyway, still no luck getting a file out.
BTW, there are some freeware/demo PCB packages that you could download- have you thought about doing that for creating your design? Then you have have a schematic with true netlisting and DRC. There's a European outfit I use for personal PCB's, they have a lot of downloads and links; plus there's the demo version of Proteous; you might find those interesting.
PCB Pool
Jon
Old 19th July 2002, 06:47 AM   #13
Dave is offline Dave  New Zealand
The CS8420 MAY specify a maximum voltage difference between to VD and VA supply pins. You should probably check your seprate regulators can supply voltages with in this difference.
Old 19th July 2002, 10:30 AM   #14
I dosent seem to be able to uppload if possible i might be able to mail it to you directly?
/micke
Old 19th July 2002, 03:14 PM   #15
You can email it to me directly; that's OK with both my email systems.
The use of seperate regulators, such as the TLV431, for the digital and analog 5V supplies hasn't been a problem for me with either the CS4390 or CS4397; I use the "high grade" versions, and 1% resistors, of course.
I also recommend using OSCON caps for the electrolytic local bypass, in addition to stacked film and ceramic for HF bypass. The best results have been with the larger MLC ceramic caps such as used for CPU VRM bypass caps; these are low impedance, low inductance, and only have price as a drawback- and they're readily available (in the states) from Digikey and others.
Jon
Old 19th July 2002, 06:23 PM   #16
It would be nice if some administrator could clear this thread upp a bit since none of the files work. i will try a last time to uppload i have reconfigured some things in my computer.
/micke
Can I get a double check on my cabinet? saabracer23 Subwoofers 23 9th June 2009 07:34 PM
double check the math tenderland Tubes / Valves 3 27th March 2006 04:48 PM
Can someone double check this sub modeling? jjkozlow Subwoofers 16 22nd July 2005 08:03 AM
My new design... double check please? Feandil Multi-Way 0 26th April 2005 03:46 AM
Copyright 1999-2017 diyAudio
