Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th November 2002, 09:41 AM   #21
>Does the digital coax output have upsampled
>192kHz digital ?
Don' t think so. Didn't find it in the specs. I have no way to experiment with this. There is a manula in podf form on the philips site.
>Allen Wright did mention something about using a
>simple R-C filtering for the DSD signal to recover
>audio - is this possible at all ?
As far as I know there is no SACD player available with a digital SACD out. So this is quite theoretical at the moment. DSD convertors tend to put rel. high levels off high frequency garbage. You probaly have to filter something.
gr Klaas
Old 14th November 2002, 09:53 AM   #22
Nicke is offline Nicke  Sweden
Nicke's Avatar
Default Onkyo DX 706
I have an Onkyo DX 706 with a few mods done,look in a previous post in this thread.
The clock is 16,9344 MHz.
There is nothing special about the clock,itīs just the regular crystal connected to a 7404.
The DX 708 has another clock and more advanced power supply,otherwise it is the same model.
The DAC SM 5861AP is probably a 18 bit DAC,at least it has 18 bit data in.You could check the digital filter and itīs settings is for 18 bit data out.
Nicke
Old 14th November 2002, 11:02 AM   #23
Quote from another forum "Found a new neat feature on the 963!
The 963sa can output upsampled CD digital! You can set it to 192khz or 96khz and both the analog AND digital output will get upsampled.
If you have one of those TACT pre-amp who can support 192khz, then you get a free super upgrade!
For the rest, you can still set to 96khz and get upgraded sound quality from your AV reciever or DAC!"
http://www.avsforum.com/avs-vb/showt...&pagenumber=14
gr Klaas
Old 29th January 2003, 06:06 PM   #24
Henrik is offline Henrik  Denmark
I have done some modification to my DX706, and I believe this goes for the DX771 too.
http://www.diyaudio.com/forums/showt...092#post120092
Henrik
Anyone tweaked a Nakamichi Cdp-2a? The one Digital Source 8 13th November 2009 08:42 PM
In need of Integra DX7711 Service manual hiwiho Digital Source 9 21st July 2008 04:36 AM
Anyone Tweaked the Sound Dynamics RTS-3 tvr2500m Multi-Way 5 9th January 2006 01:56 PM
Servo noise from heavily (!!) tweaked 16 bit CD player Dr.H Digital Source 25 30th October 2004 01:50 AM
onkyo grand Integra DX 6990 CD player ribosome Digital Source 0 14th September 2003 09:42 AM
Page generated in 0.08261 seconds (70.34% PHP - 29.66% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
