| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I've looked and looked and I can't believe there isn't a simple solution to this. I'm looking for a device that will act as a USB audio device and provide a output at up to 24bit/96KHz, ideally in I2S but at the moment I'll take anything!
I understand there are ways to use a device from TI (such as the TAS1020B) and link it to a DAC, but I think this beyond my abilities due to it requiring custom firmware and software to drive it? Thanks Ed |
#2 |
#3 |
TAS1020B and TUSB3200 will do the job but, as you point out, both require microcode. There aren't any other good USB options as far as I know.
Your best bet is to pick up a good low-cost USB interface and mod it. The discontinued M-Audio Sonica uses the TUSB3200 and is bit perfect in both Win2000 and XP with the correct WDM drivers (not the most recent ones). The M-Audio Transit is still in production, though slightly more costly, but it comes with real ASIO drivers (which are a huge plus and you likely wouldn't be able to write yourself without much additional effort). Both units have very small form factors. |
#4 |
Any idea what this microcode looks like? Surely they provide examples, bot that I can find them! Good ideas though. Cheers
#5 |
What about soundblaster extegy? They connect to USB and convert to 24/96 output or am I wrong there?
#6 |
Yeah I'm really after just the components to build something rather different for myself.
#7 | |
Needing to program the IC will also probably mean custom Windows/Linux drivers which is too much for most of us
#8 |
How good is the M-Audio Transit ?
It is not full duplex at 96khz/24 bits. Full duplex up to 48Khz 24 bits(?) I think. Any opinions on this unit ? Really small ! Thanks. Cheers, Ashok.
AM |
#9 |
Yeah, a 24/96 stream is about 5Mb/sec, with the 11Mb/sec bandwidth of USB 1 I doubt you could get and outgoing and incoming stream simultaneously at that rate. I'm also pretty sure the ADC won't be of good enough quality to warrant it anyway.
| usb 24 bit 96KHz dac | adib | Digital Line Level | 7 | 24th February 2009 01:54 PM |
| AD1864 at 96KHz ? | SandroN | Digital Source | 9 | 10th July 2007 09:37 PM |
| A/D 24bit/96khz convertor help | sunny | Digital Source | 1 | 16th October 2006 12:35 PM |
| LP>CDR, 24bit/96kHz vs. 16bit/44.1kHz, downsampling, HELP!!! | Kuja | Digital Source | 13 | 18th October 2005 06:51 AM |
| a/d converter 24bit 96khz s/pdif recording | JBL | Digital Source | 1 | 10th January 2003 11:58 PM |
| Page generated in 0.10771 seconds (79.27% PHP - 20.73% MySQL) with 10 queries |
