Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th November 2004, 09:20 PM   #1
bg4533 is offline bg4533  United States
Default Modding my EMU 0404: Can someone please verify
I am about to order some parts to mod my EMU 0404. Below is a link to a picture of what I want to do. I only care about improving the analog output of this card.
Color Codes:
Yellow: 10uF/16V caps, replace w/ Panasonic FC 10uF/25V (16V unavailable)
Red: 100uF/25V caps, replace w/ Panasonic FC 100uF/25V
Pink: 47uF/16V caps, replace w/ Panasonic FC 47uF/16V
Green: Output caps and buffers, remove and jumper
Orange: Opamp, replace with LT1364, bypass cap, Bias to class A with ~1.5mA CRD
Removing buffers:
The datasheet lists the pinout of these opamps as:
1. A Output
2. A- Input
3. A+ Input
4. V-
5. B+ Input
6. B- Input
7. B Output
8. V+
I obviously have to bridge A output to one (or both) A input, but which? The same goes for B.
Bypass caps:
I think I am just going to use a Panasonic ECQP Polypropylene here. I have not yet decided on a size. Should I bypass from rail-rail or rail-ground? Rail to rail will be easier. What are the benefits of each method (I want to know this for future projects mainly). If I go rail to ground can I use the silver box by the buffers as ground? Anywhere better for ground?
CRDs:
I have been unable to find these on Digikey. Anyone know any part numbers?
Capacitors:
I want to keep this a fairly cheap mod, so I am going to stick with Panasonic FCs for now. Are there any other caps on this board I should upgrade or are there any that I am upgrading that don't pertain to analog output? Provided the caps fit, could there be any problems with using a larger capacitance cap? Prices are about the same, so I might as well use larger ones if it won't hurt.
Thanks for the help.
Old 10th November 2004, 04:09 AM   #2
BrianL is offline BrianL  United States
First, I'd probably just replace all electrolytics on the board.
In general, if they'll fit, use larger capacitance values.
I don't know if Panasonic PP will fit for bypass. Consider
0.01uF C0G ceramic. Having long-ish leads on the
supposedly better bypass caps pretty much negates
the benefit of the better caps. Note also, that there's
a lot of HF/RF hash to kill, so your bypasses have to work
up into the RF region.
Which parts are the buffers and why do you think that?
Before just jerking them out, I'd replace with a better op-amp.
If the buffers are truly buffers, -input is connected to output.
You'd jumper from +input to output. But you need to trace
the circuit to make sure it doesn't have gain, isn't an inverting
amp, etc.
My choice for op-amp would be something like AD8610/20 or
OPA2132 (or 2134)
CRDs: One could use a JFET connected as a constant current
load or maybe just a resistor. Pick a resistor so that it
draws about 3 mA from the output to the negative supply
on the op-amp (ground, if single-ended supply)
bel
Old 10th November 2004, 05:58 AM   #3
Werner is offline Werner  Europe
Have you studied the datasheet of that AK4395?
http://www.asahi-kasei.co.jp/akm/en/...395/ek4395.pdf
Pins VREFH, VREFL, and VCOM are probably the most critical ones,
aside from the analogue supply.
Swapping capacitors may seem fun, but if (part of) your power supply voltages are generated by a switching regulator or DC/DC convertor, then strange things may happen all over the place.
Try to measure the DAC's output through the board's ADC, for instance with Rightmark freeware, and monitor the noise floor after each modification.
Old 11th November 2004, 07:37 PM   #4
Default wanting to mod my 0404
would you be willing to post details about the mods when you are finished? I would really like to mod my 0404, but guys are charging like 160.00 to do it. Thanks.
Nik
Old 11th November 2004, 09:32 PM   #5
Default Re: wanting to mod my 0404
Nik
I am a regular poster over at the Head-Fi forums. Not too many people over there have modded their cards yet and few people understand what they are doing anyway. I posted here to see if anyone here has modded these cards or if there is any other advice.
I ordered all of the parts I need to mod this card from Digikey yesterday. I couldn't find CRDs there, so I am just going to wait on that. I got the opamp, Panasonic FC caps, and some ceramic caps for bypass. It is probably around $15 in parts.
I am planning on making a bit of a modding tutorial for the people at Head-Fi. I will post it here when I finish too. Will probably be 2 weeks before I can mod the card and write something up.
E-MU 0404 USB Modification? lumanauw Digital Line Level 67 7th February 2011 08:50 AM
EMU 0404 Sound Card tripathdude Digital Source 5 23rd May 2008 04:46 PM
Low TIM, How to verify it!!! thanks a lot!! mclarenpingu Solid State 10 19th March 2008 01:39 PM
FS: E-mu 0404 USB external sound card Jack Hidley Swap Meet 2 14th March 2008 01:00 AM
Page generated in 0.10215 seconds (76.00% PHP - 24.00% MySQL) with 10 queries
