Aragon D2A upgrade path? Aragon D2A upgrade path? - Page 3 - diyAudio
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th February 2010, 01:57 PM   #21
Jim Leach is offline Jim Leach  United States
just an update:
I ordered the board last week with the R-core transformer.
Where's a good place to get some decent enclosures? I am planning to keep the transformer separate in a small box and the rest in a 19" wide (face) box.
Front panel express looks good (great in fact), but a bit pricey for one piece... I may well go with them, but I'm looking for alternatives right now...
Old 16th February 2010, 02:20 PM   #22
Bill Fuss is offline Bill Fuss  United States
RIP
If you don't mind a more spartan look check out Parmetal. I'm using a 12 x 12 x 3 with brushed alum front panel, tons of room for everything. They are very well made but not flashy.
Old 16th February 2010, 03:09 PM   #23
Thanks, Bill!
I'll check them now...
I'm there now.. Loks good!
I think the EMI/RFI shielded enclosure is the way to go for this piece.
With the transformers in place (as I am planning to go that route like you did) do ou think it can squeeze into 1 rack space, or do you think I should get a 2-space high enclosure?
Old 16th February 2010, 05:02 PM   #24
RIP
One rack space won't do it,the board won't even fit.
Old 16th February 2010, 05:29 PM   #25
Cool. 2 spaces then. Thanks for that!
I did not see any 'small' enclosures (suitable for the transformer alone) from Parmetal. Do you have another source for a smaller enclosure?
Thanks again Bill!
Old 18th February 2010, 04:33 PM   #26
RIP
Hammond probably makes something.
Old 18th February 2010, 04:56 PM   #27
Good call, Bill.
I'll look into that.
By the way, I got my shipping notification... It's on the way!
Old 18th August 2010, 02:18 PM   #28
Scabiko is offline Scabiko  Argentina
Default Aragon d2a help please!
This is my first post. I bought a DAC Aragon d2a (original series - non mk2), without the ips. As users of this dac know, the bass is not very controlled. thatīs why Aragon implemented changes shown in the mk2 version. I an looking for the service manual or schematic of the mk2 version, or at least I would like to know the value of the two large capacitors (actually, the 2 largest ones) placed inside the unit. Any recommendations on possible mods are highly welcomed. I have upgraded the Ips. Thank you in advance for your time and consideration.
Old 18th August 2010, 02:42 PM   #29
I (finaly) found a stock power supply for my 47k (same supply as the D2A, which I also have).
Anyway, also interested in what ever upgrades exist for the D2A. I was never dissapointed with it, but it is quite dated at this point.
I think I have another post asking this (could be wrong) but it may be worth searching to see what shakes out...
"When the world is running down,
you make the best of what's still around."
Old 18th August 2010, 06:29 PM   #30
hihopes is offline hihopes  South Africa
Which capacitors are you referring to? The two on the psu board or the output caps?
My D2A had a jfet output stage with 2sk149 and sj74 if I remember correctly. I think it was a buffer stage. It was part of an upgrade kit that was retrofitted.
I found benefit in changing the output caps. The ones that were fitted in mine were 10uf polyprop caps but were not very good ones. You can definitely tighten up the bass by using better ones.
Other improvements were found by fitting discrete regulators and by using good quality bypass caps (oscons). For discrete regulators, you might like to try the "teddyreg" design. I also soldered small oscons directly to the relevant pins on the dac chip. (Download the datasheet and check which legs and which polarity they are)
If you can find another one, you can try piggy-backing the dac chip. I was going to do that, but struggled to get hold of another.
Hope this helps,
William.
Aragon D2A upgrade path?Hide this!Advertise here!
Rotel RCD-991AE: what's the upgrade path? rameish Digital Source 3 4th April 2011 04:18 PM
Aragon question... bluesmoke Solid State 72 24th January 2010 02:38 PM
Upgrade path limeman Vendor's Bazaar 0 24th September 2008 02:02 AM
Aragon 4004 ben goh Solid State 0 3rd May 2003 03:55 AM
Stock NAD 3020i Upgrade path. dlarkin_dc Solid State 2 22nd April 2002 06:41 PM
Copyright ©1999-2017 diyAudio
