Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th November 2004, 08:06 AM   #1
Default Digital Preamplifier and TI
hello all,
I m v.new here. I m currently working on TMS320C6711 DSP Starter Kit (DSK Board). I have to transfer digital data from Music CD (44.1 kHz+16 or 24 bit) on to the DSK board and then perform 4 steps.
1-Interpolation: 44.1->88.2
2-Decimation: 88.2->44.1
3-SRC for Rational Factor: 44.1->48
4-Multistage SRC: 44.1->192
I have to program this DSK to function as a preamplifier and listen to the audio after all the above operations r performed on the digital audio input. TI's Code Composer Studio (C & Assembly) is to b used.
ANY one out there, who is familiar with these things in any respect must (plz) reply to this post as i m in a big trouble.
regards.
Old 9th November 2004, 09:04 AM   #2
plz help if any body knows how to cop up with this problem.
Old 9th November 2004, 09:34 AM   #3
MWP is offline MWP  Australia
Sounds like a school/uni task... sure your not trying to cheat on your homework?
Old 9th November 2004, 09:57 AM   #4
roibm is offline roibm  Romania
Banned
got him, ha?
Old 9th November 2004, 01:10 PM   #5
ya this is, can't anyone help in this regard
Old 9th November 2004, 04:41 PM   #6
gmarsh is online now gmarsh  Canada
gmarsh's Avatar
Doing this sort of work is half of my day job
You just described 4 polyphase filters. There's probably lots of examples and functions in the TI software which can do a lot of this for you, most of your work will involve calculating filter taps.
Old 9th November 2004, 04:52 PM   #7
ok gmarsh
can u guide me throught the process
i mean where to start, just guide me then once i got the right track, i will follow it on my own & what type of things do TI offer? can u plz spend some time to write this all stuff just once??
Old 10th November 2004, 12:11 PM   #8
gmarsh's Avatar
Originally posted by kami10001
ok gmarsh
ok, first things first - i'm not doing your work for you.
I haven't programmed on TI DSPs in years and I've never used a C67x DSP, so I don't recall what examples they have. If you're using one of their evaluation boards with onboard sound or onboard digital audio I/O hardware, then without a doubt the board comes with some software examples - eg, a talkthrough example.
Tackle the first thing (44.1->88.2) first... here's what you need
- two audio interfaces on the board, one at 44.1 and one at 88.2, which are synced together.
- the DSP's McBSPs (or whatever they call them now) properly configured.
- your audio processing code, which reads one sample from the 'incoming' McBSP port and writes two samples to the 'outgoing' port.
And in order to write the audio processing code, you'll need:
- to decide what the frequency characteristics of your 44.1->88.2 conversion need to be (passband ripple, transition band, stopband ripple) - eg. 0.005dB passband to 20KHz, 100dB attenuation at 22.05KHz.
- Feed this into a filter design program. Design a filter with an even number of taps, with the aforementioned characteristics and a sampling rate of 88.2KHz. Personally I use MATLAB's "fdatool" for this.
- Divide the filter into two polyphase banks. You'll need to multiply the tap values by 2.
- Either write the code for a 2X polyphase FIR filter, or see if you can find a library function which does it for you.
Once you get this done, you can move onward to the more difficult 44.1->48 kind of stuff.
If you don't know what I'm talking about here, pick up a filter design book and start reading TI appnotes.
Old 10th November 2004, 01:04 PM   #9
thank u v.much gmarsh, i will try these things out.
I have started reading all the documents that TI provide with the card, hope i will find one that can solve a part of my problem
Old 7th December 2004, 11:44 AM   #10
Default attention gmarsh: I have a query
[QUOTE]Originally posted by gmarsh
1-How to define 2 audio interfaces on the board? u mean just to configure 2 McBSP(Incoming McBSP0 & Outgoing McBSP1) for recieving data from CD-drive or PC & sending back data on the board, one (McBSP0) @ 44.1 for recieving data & other (McBSP1) @ 88.2 for sending data back to PC
2-U mean one sample should b read from the audio interface McBSP0 & two samples should b write on McSBP1
OR
the 2 audio interfaces r different from the incoming/Outgoing McBSP.then y they r defined?
Need a quick reply....
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
digital crossover w/digital output? ezkcdude Multi-Way 30 3rd August 2006 01:01 AM
Digital Preamplifier and TI kami10001 Chip Amps 1 6th November 2004 08:38 PM
Page generated in 0.11658 seconds (85.81% PHP - 14.19% MySQL) with 10 queries
