| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello.How to adjust digital signal(volume)?How to make digital volume?
regards |
#2 |
The PGA2310/2311/4311 chips from TI are very good.
I've tried using a MAX5437 digital pot in the past, but the results were awful - the Audio Precision gear gave it a THD approaching 1%. But there's probably better pots out there... |
#3 |
thanx a lot...
#4 |
is there anyway to get it to work with a micropro?
#5 |
I saw characteristics for pga chips.
I don't need to adjust analog signal digitaly.I need something to adjust digital signal. Example: Input is digital>>>volume control>>>output digital but no conversion to analog present regards |
#6 |
Usually a DSP is used for control in digital domain. For volume control maybe the DSPIC controller from Microchip would be nice as it could do the job and you could use the same chip for remote controller. In addition you'll need S/PDIF reciever and transmitter chips (see www.cirrus.com).
#7 | |
#8 |
thanx guys very much.
#9 | |
Here's what you need... deserialize - handled by a dsPIC's codec interface. multiply - 1 or 2 multiplies per instruction, depending on 16 or 32 bit data (assuming a 16 bit scale factor). Multiply by 2 for 2 channels. dither - 2 multiplies, a couple of shifts and a few adds to update a LCG generator, generate a triangle PDF and sum it into the signal. You can use the same dither data for both channels. serialize - again, handled by hardware. With a 30MHz core clock, manipulating a 44KHz (or even 96KHz) audio stream still gives you plenty of spare clock cycles. |
#10 |
somebody plz put a price/bom on these dsp solutions
$1000? $100? $10? $1?
intentionally blank |
| Digital Volume Control | soundNERD | Chip Amps | 17 | 3rd June 2011 08:00 PM |
| digital volume control | aardvarkash10 | Tubes / Valves | 11 | 10th December 2008 02:41 PM |
| Digital volume control | day1118 | Digital Line Level | 8 | 21st November 2008 08:11 PM |
| Which VCA for Digital volume control | gmphadte | Analogue Source | 8 | 30th September 2004 11:21 AM |
| Digital Volume control for in Car use | dunderchief | Digital Source | 7 | 28th March 2004 12:08 AM |
| Page generated in 0.10065 seconds (79.10% PHP - 20.90% MySQL) with 10 queries |
