Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
philips old ic for cdplayer
Old 1st November 2004, 11:44 PM   #1
pengxy is offline pengxy  China
Default philips old ic for cdplayer
Anyone can help me find datasheet of MAB8410,MAB8420. I have the block diagram but don't know how it works.
Old 2nd November 2004, 12:17 AM   #2
johnnyx is offline johnnyx  United Kingdom
I don't have the datasheet, but they are microcontroller chips, so they work with programmed code for their specific function. On Philips units, the chips have a program version number as well as the type number, and sometimes different versions work, sometimes not. It depends on how the program has been changed, and for what unit it was programmed. I think they are OTP chips, and cannot be re-programmed.
Hope this helps.
Old 2nd November 2004, 02:54 PM   #3
Here is the pictures of this chips. The left one ,which is from my cdplayer, very hot and 4.4334MHz clock not working .
Replaced with one on the right side in the picture. The clock is working now but I am not sure if it is right version that you mationed above.
The eye pattern is ok but the mute control bit of mab8420 not relaesed .
The player can't read TOC of the disc and tracking its way to the end of disc and starting from begining again,no data to saa7030.
Should both MAB8410 and MAB8420 be same version? Waht is the version mark on the top of the chips ?
It seems that only if same version can save this cdplayer .
Any suggestions?
Old 2nd November 2004, 06:12 PM   #4
From what I remember, it was about 15 years ago, the type number is something like;-
MAB8410-162
The "162" is the version number. I think they may be mask -programmed devices, ie programmed during manufacture. They are crude compared to modern PIC or AVR chips.
It is important to seperate devices by function. Controllers that control the laser pickup may be interchangeable, I successfully replaced one with a different number and it worked ok. Manufacturers add new features to their latest products, but the essential features remain the same. A controller from the keypad/display section will not work in the laser pickup section. Philips used several of these in one player, each controlling a different function. You need to replace the damaged chip with one that has at least the same function, even if the program number is different.
Hope this is even more helpful.
Old 3rd November 2004, 02:33 PM   #5
In the schematics this MAB8410 is for subcode decoding,audio output relay control and data to MAB8420(laser pickup control).
If someone knows the chip's version or old cd-players ,working same function as this one. I will try to find the chips or old cdplayer with the chips.
philips old ic for cdplayerHide this!Advertise here!
Original Philips cdplayer service documentation VanHal Swap Meet 2 10th February 2010 10:03 AM
Best opamp for my cdplayer. wandelblu Digital Source 32 7th December 2009 04:20 AM
Philips LHH cdplayer series information Bennie Digital Source 7 2nd August 2007 05:33 PM
Noisy cdplayer ? mirland Digital Source 0 21st October 2005 09:19 AM
Panasonic CDplayer SL-E10 wvwvwv Digital Source 0 30th July 2005 08:25 AM
Copyright ©1999-2017 diyAudio
