| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#131 | |
As far as I know the resistors are included to make the output more tolerant to capacitance in different signal cables. Probably it is best to keep these resistors even if you remove the transistors. I do not know the purpose of the two-transistor construction. |
#132 |
Thank you.
#133 | |
I also don't know for sure why they always seem to use a pair of transistors, unless a single transistor still provides its Vbe drop to the output and using them in pairs gives more complete muting? |
#134 |
The resistors are 75 ohms. Having one makes sense to keep the opamp from seeing a dead short, although it is internally short circuit protected. I would not see that the input to the next stage would care if it sees a dead short. I always short unused inputs with no problems so far .
I did read something about using more than one transistor to get the required muting level and also about using the resistors to stabilize the outputs to capacitive loads, but I do not fully understand either, hence my question. Thanks for the input. |
#135 |
I know that is an old topic...
But i'm starting doing some mods on my Nad C520. I changed the OP chips, the in and out cap of the amp stage, and i would like to change the 1N4001 diodes.I would like to use schottky diodes, i found 11DQ10 which should do the job quite well, i read in the topic also byw200 and SB300 could do the job... Can also the 1N5819 work? Because i can hardly find the other types of diodes...Any good substitute? thanks a lot for your help, Crim |
#136 |
Dear fellow tweakers,
Reading all the positive results with all your tweaks I wanted to share my own experience. Although this tread is based on the NAD54x series I have an older NAD 524(i). The NAD 524i is an improved version by the Dutch distributor bought in 1998 for 1300 HFL = approx 600 EUR. What they did is using a standard 524 - costing 1000 HFL - and replace the Op-Amps for better types ( the "bastards" removed the text on top so you do not know what they have used ) and they also replaced the parallel coupling caps from 0,22 uF to WIMA 2,2 uF MKT. The main coupling caps are 100 uF Elna but no specific type. The standard RCA plugs were also replaced by gold-plated heavy duty models. Since I have much better speakers I realised there would be much room for improvement in the CD / Amp area. The NAD distributor will supply a copy of any service manual for 15 EUR each so I ordered for the CD player and Amplifier (NAD 317) which really helps if you need to tweak. Earlier this year I already installed an Euro connector to be able to use better mains cables instead of the standard pre-mounted wire + plug. Starting with the cd player I decided to install a Tentlabs XO2.2 clock. Because I overlooked the installation guid on the Tentlabs site I started to search on the internet and I happened to find the site of the Autralian brand Burson Audio. In the weeks before I also had read lots about Op-Amps which were also on my to-do list and so I found the Burson discrete Op-Amp so I realised the potential here. I ordered a set and last week I installed the XO2.2 clock, discrete Op-Amps and replaced the Elna's for the Silmic II types. I was really amazed about the result. A friend replaced his Marantz SA11-S1 for a Spectral cd-player some months ago and then I had the opportunity to try his Marantz for a weekend but the difference was not that big to my ears. Now that I upgraded my NAD I could notice the difference immediately but unfortunately I can not borrow the Marantz anymore to do a new comparison. But I am sure it will blow the Marantz away... which is an expensive cd-player !! I am also planning to replace the rectifier diodes (Skottky) and power supply capacitors. The 5Vdc that feeds the analog section of the PCM1716 DAC chip is from an 7805 whicch itself is supplied by the 12Vdc (LM317/337) for the analog section. I will replace this 7805 by a LM317 too becuase of the lower noice. And the muting transistor in the output will go too. The clock and Opp-Amps are responsible for maybe 80% of the upgrade but the other tweaks are inexpensive so I will continue although the results won't be as shocking as last weekend ;-) When completely finished next week I will make some pictures for those interested. |
#137 |
Hi people, I've recently acquired the NAD C542 player and would like to see what I can do to upgrade/modify the player. Can someone with the service manual send a copy to my gmail address with user ID "friendster" (remove the quote and add [at]gmail.com). Thanks.
| 41Hz AMP2 upgrade... What parts to upgrade? | MotoMan_Yz400 | Class D | 2 | 6th March 2008 05:28 AM |
| Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? | jpchleapas | Digital Source | 1 | 31st January 2008 07:18 PM |
| Nad 541i digital in mod? | Ducataudio | Digital Source | 1 | 23rd February 2007 06:23 AM |
| what to upgrade in this dac? | lightmaster | Digital Source | 0 | 16th April 2006 11:35 AM |
| NAD 541i CD Player: purpose of four resistors? | Franz G | Digital Source | 3 | 30th April 2005 03:10 PM |
| Page generated in 0.10807 seconds (79.36% PHP - 20.64% MySQL) with 11 queries |
