Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Mod/upgrade NAD C 541i
Old 22nd September 2008, 09:27 PM   #121
HiFiNutNut is offline HiFiNutNut  Australia
10uF Clarity caps are large! They could just fit into the chasis.
I used 2.2uF only. By increasing the resistor after the coupling cap you could have a very low corner frequency without ill effect. The increased noise is so small that it can be totally ignored.
I can't remember what that resistor value from my memory, but if you use 10uF then as long as the resistor is greater than 10k it should be fine. It would not cause loss of bass.
Seriously, I would increase the bypass capacitors so that the power supply can have a lower impedance at lower frequencies. This may help increase the bass response.
Old 22nd September 2008, 10:04 PM   #122
Could someone be kind to send me a NAD541i service manual?
Bill
Old 23rd September 2008, 09:14 PM   #123
Got the NAD541i service manual now. Thanks.
Old 28th October 2008, 05:10 PM   #124
Randomizer is offline Randomizer  United States
Default replace output
nadclock,
Have you replaced the output section?
There is a universal tube output from DIY Hifi Supply that I'd like to use.
Where does the output start so?
Pat O'Malley
Old 28th October 2008, 10:23 PM   #125
Default A link to the tube output
Here is a picture and link to the tube output stage
http://www.diyhifisupply.com/?q=node/399
Pat O'Malley
Old 6th November 2008, 02:16 PM   #126
saran is offline saran  India
Unhappy No USE
Done the modification as mentioned below to my NADc542 but of no use..Now it doesnt read some other discs too..
Aparently the following has to be done in c542:
1. Change resistor R227 from 100R to a jumper wire.
2. Change resistor R103 and R104 from 20K to 15K.
3. Change resistor R218 from 15K to 47K.
4. Change capacitor C221 from 0.1uF to 3900 pF.
the resistors 103 and 104 in my C542 is not 20k.
its colour band has.. brown ,black ,black,black ,brown
Can some one send me the c542 Sevice mnual to
saravanan.cn@gmail.com
saran
Old 25th November 2008, 05:35 AM   #127
Talking Done the Mods with NAD c352
janusz,
found out the mistake, had replaced some other resistor,
Now I have done the mods properly as per your sugesstion .
The cd player is reading all the discs even the one that I compile from my PC .
Trying to do the same in my friends NAD c541i. Need service manual Can any one send me the manual for c541i
Saravanan.cn@gmail.com
Thanks in advance
saran
Old 27th January 2009, 03:37 PM   #128
canned70 is offline canned70  Germany
Default want to mod my C542
Hello all,
I want to try some mods on my C542
For this reason I'm looking for a service manual.
Maybe someone of you can help me ;-)
my email is marc.bauer at franken-online.de.de
kind regards Marc
Old 27th January 2009, 09:06 PM   #129
Default wrong mail address
Sorry, my correct address is
thanks Marc
Old 25th February 2009, 01:37 AM   #130
kelly is offline kelly  United States
What is the purpose of R375(R376) and R379(R380) in the NAD 542?
If the muting transistors are removed, can these resistors be removed?
Why are there two muting transistors per channel?
Mod/upgrade NAD C 541iHide this!Advertise here!
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
Nad 541i digital in mod? Ducataudio Digital Source 1 23rd February 2007 06:23 AM
what to upgrade in this dac? lightmaster Digital Source 0 16th April 2006 11:35 AM
NAD 541i CD Player: purpose of four resistors? Franz G Digital Source 3 30th April 2005 03:10 PM
