| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have two problems with this cd player, with some cds it has trouble tracking, and it will not play cdr's though I've read that it can, second the display is gone, if you look really close with a bright light you can see it but it does not emit any light, any help would be much appriciated, thanks
#2 |
Re tracking problem: Not all CDs have the same reflectivity. CD-Rs have even lover. The laser diode looses its ability to output a proper (high enough) laser beam. Check your PCB and look for a test point labelled RF. Insert a CD that your CD player has problem reading. Monitor the RF signal on oscilloscope and look for an eye-pattern. It should be 1.5(+ or - 0.3) Vp-p. If it is lower than 1.2V you'll have the problem where the pick-up reads some disks, and does not read ones with low reflectivity. You can increase the laser output by adjusting the little trim-pot located on the pickup itself. Do not go over 1.7 - 1.8 volts. After adjustment try CD-R disk and check the amplitude. Re display problem: Your display should have 'heating' voltage (usually labelled F1 and F2) of around 3 or 4V AC - check if this is present. Displays also use -33V DC or close to this value, and sometimes + or -5V DC as well. With your CD player being made in UK, check for burnt-out resistors in the heating circuitry. Good luck! Regards, Extreme_Boky |
| CD player problems | jmillerdoc | Parts | 0 | 22nd March 2009 12:19 AM |
| CD player supply problems | Mikhail | Digital Source | 4 | 13th December 2006 08:39 AM |
| Onkyo CD Player Problems | Fat Man | Digital Source | 0 | 13th March 2004 11:37 AM |
| JVC XL-V120 cd player problems | rbroer | Digital Source | 2 | 30th October 2003 06:30 AM |
| CDM4 player problems | rbroer | Digital Source | 7 | 24th September 2003 07:27 AM |
| Page generated in 0.11940 seconds (49.56% PHP - 50.44% MySQL) with 10 queries |
