Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd October 2004, 09:07 PM   #1
00940 is offline 00940  Belgium
Default Decoupling : ok method ?
To bypass the power pins of a dac, is this an acceptable method ? You use a low value through hole electrolytic and solder a good quality smt ceramic between its pins.
It's for a ssop28 dac and space is scare. The advantages being using this combo very near of the dac, you'd be saving a lot of space (relative of course) compared to surface mounting the ceramic. Traces and DAC being on top of the board, a groundplane on the bottom.
Old 23rd October 2004, 09:10 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
Seems acceptable to me, maybe soldering them is more difficult than the conventional methods.
It's only audio
Old 23rd October 2004, 10:50 PM   #3
sek is offline sek  Germany
Why don't you solder the smt cap between the pins on the underside of the board? I would consider this a standard technique, as the cap will definitely fit inbetween the electrolytic's pins still on it's own pads. Thus, no tricky difference between schematic and board, no difficult work to solder the smt cap, no waste of real estate and an only insignificantly longer trace between cap and dac. Also, the now elevated electrolytic could be prone to vibration and shortened life span.
Sebastian.
PS: I regularly solder smt components between tth pins.
Old 24th October 2004, 12:47 AM   #4
sometimes you're just missing the obvious.
Easier for sure.
Ben.
Old 24th October 2004, 04:37 PM   #5
Old 24th October 2004, 04:54 PM   #6
jackinnj's Avatar
When making a single-sided board, I put the SMT components on top and the through-hole ones on the bottom -- you just have to remember to do all the SMT devices first.
What's the best method to rip CD to HDD? kop89 Digital Line Level 124 24th June 2009 04:56 AM
Anyone tried this method for OTL? jerluwoo Tubes / Valves 3 23rd November 2006 11:46 AM
Decoupling richie00boy Parts 9 13th November 2006 04:31 PM
Decoupling caps(again) argonrepublic Parts 2 10th May 2005 10:32 PM
decoupling PCM1716 Smiffy Digital Source 6 6th February 2004 01:24 PM
Page generated in 0.09272 seconds (77.71% PHP - 22.29% MySQL) with 11 queries
