Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd October 2004, 04:36 PM   #1
vit is offline vit  Sweden
vit's Avatar
Send a message via ICQ to vit Send a message via AIM to vit Send a message via MSN to vit
Default Plz, comment my layout (D1 I/V)
Hi guys.
What's good, what could be better?
Trace width:16 mil
E-Caps: Panasonic FK
Caps: WIMA SMD
cheers // vit
Old 25th October 2004, 06:06 AM   #2
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
looks very professional.What is it used for doing?
A suggestion is to avoid the "T" type trace.
digi
Old 26th October 2004, 08:49 PM   #3
vit's Avatar
Hi and thanks digi01. The software I use is Eagle Layout Editor by Cadsoft .
Old 28th October 2004, 11:26 AM   #4
Banned
some questions:
why do you use 390R instead of 1k5 at R27 ? do you think more voltage across the FET is better?
why do you use 10nF for C3? i think in the original this one would be the 2n7.
Do you use a less +-30V power supply? for the 3k3 resistors i think 1 or 2 watt type would be better.
very interested, Till
Old 29th October 2004, 07:26 PM   #5
vit's Avatar
Hi Till
I asked someone (can't remember who ) if I had to adjust something in the circuit for a higher output dac.
I will use PCM1794 wich have 4x higher output then PCM63.
edit:
Yes, the 3k3 resistor is 2W.
BTW...I will use your power supply
If you are intrested I'll send you my eagle-files
cheers // vit
Comment on my layout please yan6 Chip Amps 4 22nd January 2009 05:28 PM
Comment on my layout please Iain McNeill Chip Amps 0 22nd January 2009 01:51 AM
Please comment this PCB layout megajocke Solid State 0 10th December 2008 03:20 PM
Please comment on parallel DAC layout mozilla Digital Source 0 29th September 2004 10:03 AM
REQ Comment on PCB Layout lubbie Solid State 4 20th September 2004 10:27 PM
Page generated in 0.09844 seconds (80.37% PHP - 19.63% MySQL) with 11 queries
