Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd October 2004, 02:09 PM   #1
Alfetta87's Avatar
Question Coupling Cap 220µF - the best is...
I was just tweaking the Audio Board of my DVD 2900: just after the output OpAmps (replaced by Dual AD825 devices), there is a 220µF/50V polarized (Elna Silmic II) as a DC blocking cap, in parallel to this a set of polarized - inverted connected (+ to +) Silimic (not II) of 2.2µF/ 50V.
I'd like to experience to get a better sound. Actually, to player is bright without going too far, but there is a lack of presence in the low midrange which takes some natural from the music. Compared to a Copland CDA288, the player sounds thin, even there is bass.
Haven't changed anything yet in the PSU, would start to change the 220µF to another, and replace the 2.2 against a single Auricap 1.0µF.
What would be the best Electrolytic Ersatz for the 220µF?
Thanks,
Dan
It is worth to keep your mouth shut and let people think you’re stupid; rather than to open it and thus eliminate any doubts...
Old 22nd October 2004, 02:40 PM   #2
analog_sa's Avatar
The Silmics are excellent. BG will be marginally better but don't expect a transformation. Why on earth do they use such gigantic values anyway?
Old 22nd October 2004, 02:56 PM   #3
Alfetta87's Avatar
No Idea, why such high value. Will try lower values though.
Have also a pair of Balck Gates X, non polarized, maybe they worth it?
Dan
Old 22nd October 2004, 04:24 PM   #4
Default Re: Coupling Cap 220µF - the best is...
Thanks,
Dan
You should try the BG FKs without bypass initially. You must burn in for a couple of weeks. The 825s are smoother with two FET current biasing to 3 mA or so.
The BGs are way better than Silmics; but you must use FKs or Cs if you thinkl FKs are too expensive.
Old 22nd October 2004, 04:26 PM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
One of the mods performed by Partsconnexion to Shanling player is instaling in output coupling position two BG STD 220u caps (back to back) with 2.2u Auricap in parallel to that. It sounds pretty good this way.
I also don't know why those capacitances are so high.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 22nd October 2004, 06:14 PM   #6
[QUOTE]Originally posted by Peter Daniel
[B]One of the mods performed by Partsconnexion to Shanling player is instaling in output coupling position two BG STD 220u caps (back to back) with 2.2u Auricap in parallel to that. It sounds pretty good this way.
I have never liked back to back connections for caps; you ens up with signal going thru' 2 caps whatever the alleged theoretical benefits are.
You also probably don't need 220u. 100u or even 47u will do. For 47u, there is the BGNs.
Old 22nd October 2004, 06:42 PM   #7
They would probably get away with 4.7u as well.
And BG N are pretty good for coupling.
Regarding the previous way of connecting caps, I wouldn't do it that way either, nevertherless, I was surprised it still sounded decent.
www.audiosector.com
Old 22nd October 2004, 07:00 PM   #8
Alfetta87's Avatar
The DVD 2900 is supposed to be a High Quality player (when not High End), maybe for this purpose high value of 220µF is considered to be usefull in any situation (regarding the frequency response towards the LF) - whatever the connecting impedance would be. But the situation is that a preamp after the Denon could have a coupling cap as well - as it is the case with my BP 25 from Bryston, which has 100µF Roederstein ElCaps in the signal (before the electronics). My other, SRPP home made tubeamp (5687) has no input cap, so there is a need of a cap in the Denon, otherwise any cap would stay outside.
Will try smaller values and see how it works.
Dan
Old 22nd October 2004, 11:26 PM   #9
Hi Alfetta87,
I have used AURI capacitors instead of various combinations of electrolytic capacitors with by-pass caps. In my opinion, a single capacitor in signal path is mandatory for a good sound! Try 4.7uF/200V AURI caps. Try to connect them from the output pin of your AD825's straight to the RCA connectors - AVOID pcb tracks! Be careful to preserve muting functions, as well as a proper RC loading of your output OP amps.
I must say that I have used Black Gate capacitors as well. I tried C type for signal coupling, N and NX in both stand-alone and super E cap configs, FK types... To me, 10uF/50V type C Black Gate sounded the best, but not as good as AURI caps. I love Black Gates in power supply filtering applications, as well as IC power supply rails high frequency decoupling applications where 0.1uF/50V NX type is absolutely fantastic. However, for the sound coupling, AURI caps are better. There are other high quality (and high price!!!) film foil capacitors around - but I haven't tried them. AURI caps are reasonably priced and sound open and natural.
Extreme_Boky
Coupling cap before or after pot? sharpi31 Parts 11 26th May 2008 06:02 PM
ESP P3A coupling Brownlow Solid State 1 30th August 2003 08:46 PM
Coupling cap Raka Chip Amps 11 9th June 2003 01:06 PM
What does coupling mean? EternaLightWith Tubes / Valves 53 5th January 2003 09:35 PM
Help with DC coupling. G Solid State 11 20th September 2002 06:58 PM
Page generated in 0.21195 seconds (66.38% PHP - 33.62% MySQL) with 10 queries
