| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have just aquired an Alpine 3900 DAC and have a question regard a CD transport:
Does the quality of a CD transport matter at all in terms of sound quality? if so, then why? I figured that binary 10100 is 10100 wether it comes from a $80 DVD player or a high end CD player, make sense? ![]() Thanks Max |
#2 |
The transport matters. Quite a lot actually, if you a good setup.
Reducing vibrations and deticated power supplies they all matter in a transport.
"I`m not the messiah!" |
#3 | |
I tend to think of it as digital magnitude with "analog" timing. Since it’s the transports job to "create" the timing, it’s a significant part of the overall system. Just my two cents. Doug |
#4 | |
#5 |
Jitter is fairly important to digital audio. The whole concept is to sample a signal at discrete points in time, and then reproduce the samples in the same sequence, and at the exact same speed. A steady clock is very important for this. There's a fairly high tolerance for data clocked into a DAC, the clock would have to be way off for a 1 to be read as 0 and vice versa. The low jitter clock is important for instructing the DAC on when to change the output from one code to another.
As for virbrations in the transport, well that's a load of hogwash. Vibration in the transport is only a problem if the vibration is bad enough to cause a skip. No transport is skip proof. No mechanical system will be immune to vibration, that's a veritible fact. You can tune it to specific frequency, and dampen it, but if can never be eliminated. |
| Computer as CD Transport with Quality DAC | eeyore | Digital Source | 0 | 9th January 2009 04:29 AM |
| DJ CD player = high quality transport? | sharpi31 | Digital Source | 1 | 31st August 2008 04:28 AM |
| quality of pioneer PD-S703 as a transport | ronardi | Digital Source | 14 | 18th May 2008 03:35 PM |
| 8 channel 24/192 DAC: The transport question | NeoY2k | Digital Source | 5 | 21st April 2008 08:36 PM |
| Best quality and lowest jitter Philips transport assembly? | mburnstein | Digital Source | 8 | 13th January 2003 09:20 PM |
| Page generated in 0.08196 seconds (73.98% PHP - 26.02% MySQL) with 10 queries |
