| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
as I like to play first time with various DAC chips outside CDP as there are TDA1541, PCM56, PCM58 and PCM1702... and in the data sheets signals always have different names, I am lost. For TDA1541, how can CS8412 be connected to SAA7220 ? And which OS filter I best use for other DAC chips ? I have SM 5813 and SM 5841. In SM5841 data sheet I saw sample/hold used with two PCM58. Why ? Main problem is that in SM5813 datasheet I see 4 signals input but CS8412 has only 3 signals output. How do I have to connect CS8412 to SM5813 to use above PCM chips ? Bernhard |
#2 |
Banned
Crystal calls them:
MCK, SCK, FSYNC and SDATA. Don't ask why they make it so hard to understand................ Jocko |
#3 |
CS8412 to SAA7220.
CS8412 OUTPUT FORMAT 2 SDATA => DAAB FSYNC => WSAB SCK => CLAB MCK => XIN CS8412 to SM5813. CS8412 OUTPUT FORMAT 5 SM5813 CKDV = HIGH SM5813 CKSL = LOW SM5813 COB = HIGH SDATA => DIN FSYNC => LRCI SCK => BCKI MCK => XTI |
#4 |
Thanx a lot !
#5 |
What mean :
OUTPUT FORMAT 2 and OUTPUT FORMAT 5 ?? Thank |
#6 |
The FORMAT depend on the Digital Filter chip you are using ??
How you can operate the SC8414 in 2 Format or 5, ? please |
#7 |
Select with M0 to M3 pins.
#8 | |
And how can the CS8414 be connected to the SAA7030 ? And the SAA7030 would be connected to a TDA1541A. I think of that because the CS8414 do have SPDIF input. Here is the SAA7030 data sheet; http://www.elenota.pl/upload/saa7030.pdf Thank Bye Gaetan Last edited by gaetan8888; 21st December 2009 at 09:23 PM. |
#9 |
Not without some difficulty.The SAA7030 expects the audio data to be in offset binary form. The CS8414 outputs two's complement data. Somewhere buried in the forum is a circuit to convert from OB to TC.
#10 | |
I will look for that circuit to convert from OB to TC. And for SAA7030 to TDA1541A, any suggestions ? Thank you Bye Gaetan |
| need help wana change 60-Hz twin-T notch filter to 279 Hz filter | prorms | Solid State | 0 | 9th February 2008 11:38 PM |
| active filter from rod elliot and sub filter questions | wuffer | Parts | 0 | 2nd October 2005 01:12 PM |
| Wtb: Cs8412 | DonJuan | Swap Meet | 1 | 12th March 2003 10:26 PM |
| AD1853 connect ZAP filter 1 or 2 | nFORCE | Digital Source | 1 | 18th January 2003 12:11 PM |
| chassis-mounted filter or IEC plug filter | jarthel | Solid State | 7 | 11th March 2002 10:17 AM |
| Page generated in 0.10198 seconds (79.42% PHP - 20.58% MySQL) with 11 queries |
