| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have a CD63SE player which I want to modify. I will be doing the reclocking as in the website http://www.acoustica.org.uk/. I wish to remove the muting transistors and replace them by a relay. I want to know if any members have done this and would like to know how to go about it. Alternatively, how much noise comes out of the player if I don't use relays?
For the opamps replacement which are the better substitutes? opa2134, opa2604 etc. thanks, Dinesh |
#2 |
horrible noise comes out "sometimes", if you don't use anything. IIRC the noise is disc/track dependant.
We will pay the price, but we will not count the cost... |
#3 |
no need for a relay, just rip'em out...done that with two CD63s, no problem...
I have used OPA2134 in my players, but also 2x OPA627 on a Brown Dog, curiously on one player the difference between OPA2134 and 2x OPA627 isn't noteworthy, while on the other it is like day and night... cheers t btw. do a search here and you will find a lot about modding the CD63 and CD67 |
#4 |
i forgot to mention; mines the KI Signature model.
#5 |
Hi Mark25,
I have upgraded two Marantz 63 CD players. Fortunately, you do not need any relays installed, just remove muting transistors. I have also installed a clock in both and large number of Black Gate capacitors. All power supply rails "in-series" resistors (4.7 to 10 ohms, sometimes 22 ohms as well) have been replaced with ferrite beads - big improvement!. OPs are AD826 (very good to excellent), but you could try AD8066 which are outstanding (I use them as I to V converter in dual differential 1704 config in my Denon CD player - EXCELLENT. However, 8066 need attention - they can overheat even with + and - 12 volts rails, which is maximum for these. I have used thermal heatsink compound and little copper heatsinks - and they run perfectly okay. You also need adaptor boards for 8066. You could cut-out back panel and install an IEC power connector, which will allow you to use high quality power cable. The signal coupling capacitors are replaced with two AURI 4.7uF / 200V caps. The HDAM sections are NOT in use any more - the signal is coupled from the output pins of AD826 via AURI caps straight to the (high quality) RCA connectors. This signal DOES not travel via PCB tracks any more - things I learned from many years of valve gear modifications. The driving capability of AD826 is very good and they do not need additional HDAM buffering. I also use pure silver ribbons as conductor, but I get these from a friend of mine. Solid core copper cable is also very good. At the end I replaced the membrane ribbon cable which connects transport with main PCB and I used high quality silver wire and I soldered both ends. This mod was a bit Extreme, but the result was superb! The external clock (I use XO2 and XO3) needs separate power supply! This is very important. These machines were easily better than anything in 3000 to 4000 AUS dollars range on the market. I also used copper shielding and vibrations deadening... Good luck! Extreme_Boky |
#6 |
thanx for the interesting reply Extreme_Boky.
I removed the mute tr's from my KI sig, but put them back due to the horrible noises, thinking about it, maybe it was just on "skip", that the noise ocoured, maybe i'll investigate this again sometime soon. i think i'll stick with the original power cord, i like the idea of no IEC connector! What benefit does the AD826 bring over the jrc op-amps originally installed? I may go for this upgrade and i like the idea of wiring the o/p pins of the op-amp straight to the rca's, that's my kind of upgrade! Cheers
#7 |
I have been following and performing most of the suggested mods; clock, caps, bypassing, removing mute x-sistors, etc, with great improvement in sound. Unit now has a soundstage instead of a flat 2D presentation. Attack on piano notes very good. Strings and violins almost sing. My problem is that the bass, while very extended, lacks definition or impact. What should I do?
#8 | |
btw, for copper shielding I use the 3M copper tapes. |
#9 | |
In my opinion, main reservoir capacitors should be located ONLY at one point along power supply rails. Local decoupling should be done ONLY with small values - with excellent little 0.1uF / 50V NX. So, experiment with power supply and you'll get what you're after. Nick |
#10 |
I have a KI sig and recently had a play with a RAKK DAC, it made a massive improvement in the bass impact. All i know is that it was optically linked to my player, do a search for the spec/technology - but they're not cheap IIRC.
Mark
| Rotel Amp mute relay/cap? | toolkit | Solid State | 4 | 3rd November 2007 06:09 PM |
| replacing amp transistors | elaar | Solid State | 52 | 13th March 2007 10:25 PM |
| general purpose relay to mute/ground outputs | mazurek | Parts | 1 | 27th February 2006 02:29 PM |
| Removing output mute transistors on a CD player | filholder | Digital Source | 6 | 1st April 2005 02:44 PM |
| Replacing speaker protection relay | chrisk | Parts | 1 | 9th February 2004 10:38 PM |
| Page generated in 0.11051 seconds (83.35% PHP - 16.65% MySQL) with 10 queries |
