Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC?
Old 11th October 2004, 03:59 PM   #11
Hattori Hanzo is offline Hattori Hanzo  Switzerland
So......you want to take out all of the filtering?
Yes, as a proposal to answer some (all?) of dieringe's questions. Compared to his intention (receiver, DF, clock, PCB etc.) this would be an easy and worthwhile experiment. I cannot really comment on the DF1704 though.
Why?
Maybe because it might sound good?
Ever hear of IMD and aliasing?
Yes, and also about the various debates regarding the filterless versus filtered approach. I didn't say the filterless way sounds best under all circumstances but I would at least give it a try. And it doesn't hurt...
Old 11th October 2004, 07:25 PM   #12
borges is offline borges  Norway
Without analog filtering, you get linear phase response. However, designing a linear-phase digital filter is actually hard to avoid, no matter the rollof.
Greetings,
BÝrge
Old 11th October 2004, 07:27 PM   #13
Martin,
mail me your email address and I'll send you my Eagle library featureing the 1704 and other oddities.
Greetings,
BÝrge
Old 11th October 2004, 08:33 PM   #14
Jocko Homo is offline Jocko Homo  United States
Banned
Default So what about "linear phase response"?
Too bad every signal encoded onto a CD is run through a brick wall on the A/D end.
It doesn't hurt?? Your tweeter may not agree.
Jocko
Old 11th October 2004, 11:02 PM   #15
dieringe is offline dieringe  Germany
Default Re: So what about "linear phase response"?
the tweeter shouldn't bother, it's a lowpass filter itself if it isn't a supersonic tweeter
Old 11th October 2004, 11:10 PM   #16
Banned
Default No, it won't "bother" it.....
Just make more HF thash.
Enjoy the sound!
Jocko
Old 11th October 2004, 11:14 PM   #17
Default Re: Re: Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC?
Originally posted by Fabian
Yes I've compared slow vs. fast roll of and I prefered slow filter. Switching the filter response is quite easy to implement. Just compare and see what's more apealing to your ears.
As you've already removed the filter from your D1 outputstage, I guess you will like the soft roll of setting. Removing the whole digital filter is like going one step further.
well my perception is that the fast roll-off gives a little better resolution, the slow roll-off gives a more analog-like sound. can't really decide which I like better.
I have another question:
6. there is a bunch of capacitors at each PCM1704. As this is HF stuff I guess tantalum electrolytics are the preferred type?
m.
Old 12th October 2004, 01:38 AM   #18
vit is offline vit  Sweden
vit's Avatar
Send a message via ICQ to vit Send a message via AIM to vit Send a message via MSN to vit
I wouldn't use tantalum caps. It's better to use OsCon electrolytics bypassed with a ceramic or MKP film cap.
Recommended paper written by Guido Tent
Check out Olimex for cheap proto PCB.
//vit
edit: Olimex recommendation
Old 12th October 2004, 02:38 AM   #19
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC? Send a message via AIM to Peter Daniel
Default Re: Re: Re: Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC?
Here's what Madrigal's using in their $17K DAC . The chips under nude Vishays are PCM1704 http://www.marklevinson.com/image_li...30_6DAC_lo.jpg
To order kits contact me through forum mail.
Old 12th October 2004, 05:00 AM   #20
rfbrw is offline rfbrw
Default Re: No, it won't "bother" it.....
Enjoy the sound!
Jocko
If he can do this
<snip>
I think I can hear some aliasing
<snip>
with a 8x oversampling dac, he may well enjoy the HF hash.
Optimizing a CS8414 + DF1704 + 4x PCM1704 DAC?Hide this!Advertise here!
FS: Complete PCB Adapter for PCM1704, DF1704 and CS8414 A'af Swap Meet 4 25th January 2015 04:55 PM
The Schematic of CS8414 --&gt; DF1706/1704 --&gt;PCM1704 XTAL Digital Source 17 15th December 2004 11:49 PM
CS8414 to DF1704 wiring Jonnravn Digital Source 2 18th November 2004 07:01 AM
