Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 5th October 2004, 10:36 PM   #1
hiwiho is offline hiwiho  Germany
hiwiho's Avatar
Default Nakamichi mute section disable
Hey!
With all but one problems solved on my nakamichi cd player 4, the last remains tricky:
I've got strong harmonic distortion on all analog outputs which hasn't gone away after changing the opamp in the analog section - so I started measuring with the help of pure sine and my computer soundcard. I've got a clean signal on the digital output, only minor distortion on the analog outs of the ad1864, even after the opamp. Only thing between opamp and analog out ist the dc coupling cap (Nichicon muse 47my/16v) and the mute section, build by two 2sc2878 per channel. Could it be an error in the mute section driver causes massive harmonic distortion to the signal?? Check out the attached screenshots.
The distortion is equal on both channels... Do I risk pops or noise while skipping when I remove the mute transistors? Finding an error in their driver section would be quite hard for me - the manual gives no info about the mute signals specs...
Matthias
can I disable van of my PA-amp? keyser Solid State 3 15th February 2005 04:59 AM
LM3886 Mute Disable mothman Chip Amps 9 19th May 2003 01:38 PM
disable oversampling j baldam Digital Source 1 3rd April 2003 06:05 PM
disable oversampling j baldam Digital Source 1 3rd April 2003 03:29 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 10:54 AM
Page generated in 0.07167 seconds (66.80% PHP - 33.20% MySQL) with 11 queries
