Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD-60 only POP :-)
Old 4th October 2004, 09:56 AM   #1
seppstefano is offline seppstefano  Italy
seppstefano's Avatar
Unhappy Marantz CD-60 only POP :-)
Hi all,
a dear friend of mine has a Marantz CD-60 with reading problems. It keeps on skipping, ticking and popping while playing. The lens seems clear enough (i'll clean it better), but I fear the problem is located in another place...
Perhaps the laser is burnt out? The power supply???
Please, share any suggestion and (if possible) Cd-60 technical schema, too :-)
TIA for any help,
Stefano
Old 5th October 2004, 11:31 PM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Replacing the laser seems to be the solution.
It's only audio. Member of the non modular PCB design committee
Old 8th October 2004, 02:42 PM   #3
Extreme_Boky is online now Extreme_Boky  Australia
Hi Seppstefano,
Check your PCB and look for a point labelled RF. Monitor the RF signal on oscilloscope and look for an eye-pattern. It should be 1.5(+ or - 0.3) Vp-p. If it is lower than 1.2V you'll have the problem where the pick-up reads some disks, and does not read ones with low reflectivity. You can increase the laser output by adjusting the little trim-pot located on the pickup itself. Do not go over 1.7 - 1.8 volts.
Extreme_Boky
Marantz CD-60 only POP :-)Hide this!Advertise here!
Marantz CD-73 Edo33 Digital Source 1 31st May 2011 02:19 PM
Marantz cd-32 ObliVion Digital Source 3 15th July 2007 10:25 PM
Right speakers for Marantz PM8000 + Marantz CD67-OSE? betto80 Multi-Way 2 24th May 2005 04:21 PM
Link Between Marantz CD12 and Marantz CD99 Mesh Digital Source 16 7th November 2003 07:08 PM
Marantz T-1 stigla Tubes / Valves 4 17th October 2002 02:11 PM
Copyright ©1999-2017 diyAudio
