Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd October 2004, 11:44 PM   #1
hiwiho is offline hiwiho  Germany
hiwiho's Avatar
Question only reading cds after warm-up
despite the other thread, my nakamichi cd player 4 has a strange problem. If the rooms temperature is less than 20degrees celsius, the player only reads cds after some minutes warm-up and might even quit while playing under cracklin' noise. What is that? Laser unit needs to be replaced?? It's a kss210a - has the player to be adjusted after replacement? The pcb offers VCO, EFM Signal, EF balance, focus gain and track gain adjustment but needs a special test. Neither do i have this nor the 2channel oscilloscope (but the service manual)...
thanx, matthias
from berlin/germany
Old 4th October 2004, 12:16 AM   #2
hiwiho's Avatar
OK, see other thread: Skipping and failure during play is unfortunately caused by a damage to one of the gear wheels of the ksm210 drive unit.
Warm up problem still unsolved...
matthias
Old 4th October 2004, 04:48 AM   #3
Try resoldering the components if the unit is old enough
Old 4th October 2004, 09:31 AM   #4
hiwiho's Avatar
Yes, its a circa 1990 nakamichi and I started resoldering until I found that mechanical failure in the drive. Won't be able to verify resoldering until i get a new gear wheel - and that's gonna be hard enough
Old 4th October 2004, 08:58 PM   #5
Netlist is offline Netlist  Belgium
Netlist's Avatar
I don't know about Germany but there's a dealer/service center in the Netherlands.
Here's the address:
TRANSTEC BV
SCHIEDAMSEVEST 71
3012 BE ROTTERDAM
tel: 010-4147055
http://www.transtec.nl/
They are expensive
/Hugo
Old 4th October 2004, 09:03 PM   #6
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
I have the same exact warmup problem in my Marantz 53 cd player. It's a '91-'92 model. I just leave it on, but I would like to resolve it.
Vince
Old 5th October 2004, 06:01 AM   #7
Default round cracks in solder points
Take a look at the solder points especially near and around the hot components (if too old, then everywhere), you will find a circle on the solder points which is a crack. This opens the connection, and probably makes connection due to expansion when the device is kept on.
Use lens or eye loupe if having sight problems for close observation.
Solder the cracked points (its best if done for all the solder points) but care should be taken not to form solder bridges.
Change all the electrolytics that are close to hot devices.
Beware: Take all the precautions necessary in handling.
Gajanan Phadte
Old 6th October 2004, 06:22 AM   #8
hiwiho's Avatar
A massive resoldering did the job - I had to work on it anyway cause of my distortion problem. Bought the whole thing cheap for only 12euros and it very much looks like it's seen some service before...
matthias
saa7220 gets warm?? jnewbold Digital Source 13 28th October 2008 09:11 AM
Help!!ETD core warm Xaudiophile Power Supplies 9 19th May 2005 04:49 PM
SI T-amp warm-up? irss Class D 3 8th April 2005 11:40 PM
My amp gets warm... Jye Multi-Way 6 21st November 2003 11:53 PM
I/V OPA627's getting warm?? MWP Digital Source 6 17th September 2003 10:37 AM
Page generated in 0.08524 seconds (83.78% PHP - 16.22% MySQL) with 10 queries
