| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi to all !
I have one small problem with my vu meter built on my LM3915 IC chip. I set current values for all all leds and the input signal but i'm confused with setting of gain How can i make the IC to show at pin1 -18db or any other value that i want. I want a scale from -18db to 9db in 3 db steps. and another scale from --12db ---> +12db for other vu meter Please help
#2 |
Electrons are yellow and more is better!
Please check the datasheet first.
http://cache.national.com/ds/LM/LM3915.pdf Secondly, the "gain" is set by the reference voltage, meaning the DC voltage for obtaining 0dB (all LED's on). You must also have a rectifier circuit with average or peak function. All this is in the datasheet.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
I don't understand what is the need of an rectifier circuit in a vu-meter. I read LM3915 datasheet but is too heavy to understand.
Please help All i want to do is to make a vu-meter with a log scale : -24, -21, -18, -15, -12, -9, -6, -3, 0, +3 dB Difference between LM3915 & LM3916 ....
#4 |
The 3915 has equal steps of 3dB each.
The 3916 is non-linear (designed for VU meters) with steps at -20, -10, -7, -5, -3, -1, 0, +1, +2, +3 dB. |
#5 |
I think you have to read the datasheet, look at the pages at the end where you have very practical advices.
A rectifier with averaging or peak function will create a more "steady" light (looks nicer) but as I understand the LM391x can handle pure AC signals also. You must adjust the reference voltage so it corresponds to the voltage or your +3dB, 1.4 volts maybe?
#6 |
What about this circuit:
http://users.otenet.gr/~athsam/vu_meter_3.htm What are the dB stages on each led ? If I load a signal between 60mV - 1.25V all leds will be lit to 0dB ? |
#7 |
I have a soundcard Creative PCI 128 2 channels
I don't have a multimeter to check the output power... What is the power in mV on spk output . Anybody knows ????? |
#8 |
Where I can find a vu-meter based on this IC but with peak hold function or a max hold function.
How can I add such a funtion. I did not find any documentation on this in the datasheet thx |
#9 |
I'm afraid that you'll have to read the datasheet in order to get a working VU-meter. If you check the "Application hints" you'll find a couple of rectifier circuits, check especially page 11, figure 4.
http://www.national.com/ds/LM/LM3875.pdf
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| ESL questions. | SDS | Planars & Exotics | 3 | 28th March 2004 01:09 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.08552 seconds (85.91% PHP - 14.09% MySQL) with 10 queries |
