Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 23rd September 2004, 12:47 PM   #1
Biskit is offline Biskit  United Kingdom
Default Clock for CD63KI
Hi Everyone,
I have been tweaking the CD63KI – replaced all electrolytics, acouctica clock hack, lead damping on base and lid, shielded and earthed main processor chip and installed switch to kill display (courtesy of Martin at acoustica).
I have decided now is the time to add a new clock. The main suspects being:-
Audiocom clock being advertised on e-bay for £54
A Net Audio Clock MKII
Guido’s XO-2
Elso’s DIY clock
LCAudio
Audiocom - not a favourite company of mine.
Net Audio - looks good and would fit neatly inside the CD63; I would want to keep the board on the main PCB so I get the main board out without having to disconnect the clock board.
Guido - looks good and I like the fact that it has more than one output. Also have e-mailed Guido a few times and found him very willing to help the novice DIYer, although he will not supply kits.
Elso's - would be happy to have ago at his clock but I don’t have access to a scope, which I assume you would need to tune the crystal. Also there has been mention of a version 8. Wouldn’t make sense to make a version 7 now.
LC Audio - very professional looking but too expensive.
Views on the above would be welcome although it seems you end up having to “suck it and see”.
More importantly what would advice be for the power supply. Does anyone have a schematic for a straightforward supply you could use with any of the above clocks.
Elso suggests that the players own digital supply is best. I would intend to use this to start with; however there seems to be differing views on the best place to take the supply from.
Can anyone give me a definite answer. Do I take it from the 7812 reg at the back of the player or the 7805 in the middle. Elso says take the feed from the Digital supply which I think would mean the 7812 (+12v).
Last but not least, op amps. The choice is so bewildering. Once tried some Bur Brown’s in a CD80 (based on advioce from Audiocom) and was very disappointed. The LM6172 seems to be a favourite, although it needs careful bypassing. Loads of various Analogue Devices, although the AD8065 seems to stick out.
Have been recommended the following as a cost effective alternative. It’s the Elantec EL2244, a symmetrical video op amp, which you can get from Farnell for about five pounds each. Here’s the data sheet http://www.intersil.com/data/fn/fn7059.pdf
Apologies for the war and peace, but I would appreciate any views the forum might have.
Old 23rd September 2004, 02:40 PM   #2
Zombie is offline Zombie  Sweden
The digital supply is the 7805 in the middle. The 7812 is the supply for the opamps and the HDAM = analogue supply.
The "digital" supply also feeds the analogue supplies of the DAC and servo etc.
You could also use the +10V just below the 7805 and add a regulator from there.
Look at the Acoustica site for more on this...
If I would be you, I'd take the time to measure the 10k and 27k resistors before the opamp (and put 1% 120p caps ) and see if each balanced input is matched. If you match the values within 0,1% it will be a big difference, especially if they are like 1-2% matched now.
I made the Acoustica clock mod and when adding an LCClock2, there wasn't any big difference.
Believe you get more response if you clean up the 5V and the 12V supplies and check what to do over at the servo and motor side. There's obviously a lot of noise coming in to the 5V from there...
Tom
Old 23rd September 2004, 03:06 PM   #3
Tom.
Thanks for the info re which reg to use.
I'll definitely check out the op amp situation.
On supplies, do I take it that I would be better off adding a separate supply for digital and analogue, maybe in a separate box.
I've read that some have not got much improvement from adding a new clock after doing the the acoustica hack but surely it comes to a point where you’ve exhausted everything else and all that's left is to put a better clock in. I appreciate its the law of diminishing returns but as someone put it you could spend a lot more on just a mains or interconnect cable and not get much return.
I think I fall into that category of DIYer where a little knowledge can be very dangerous for the health. I can follow a schematic and use a soldering iron and meter but guessing at values is out of my league.
Thanks agian.
Old 23rd September 2004, 03:08 PM   #4
Hi there - got your last email but lost it in a disc meltdown! Sorry for non-reply.
Others here will give you many opinions on opamps to use, but AD8620s are very, very good in this application. Whatever you chose, be sure to add local bypass caps across the pins - say 0.047 or 0.1uF ceramic types. The opamps are exposed to a lot of HF digital noise from the DAC (which has raw PWM output) so such bypass is critical to stability with fast opamps.
The 5v digital line is *very* noisy. Tap off the ~10.5V raw supply to the 7805 and use that to feed local (digital) regulators when required. A good idea is to add separate 5v regs to feed the DAC. The 5842 DAC has three 5v supplies, for the output stage, digital filter and oscillator gate stages. Feeding these from three separate regulators is thoroughly worthwhile. You can even do the same thing for the 7345 decoder if you really want - it has 'analogue' and 'digital' supply pins which can be fed separately. The decoder doesn't affect sound but here it distributes the clock signals to other parts of the player.
Oh, and don't use the analogue-side 7812 to feed digital circuits (including a new clock) - the digital noise will appear on the analogue side through the common impedance of the ground planes, even if your regulation was perfect.
Old 23rd September 2004, 03:53 PM   #5
Thanks Martin, feel better that you weren't ignoring me.
By the way what wer your thoughts of using the 470uf Silmic to replace CD04 (which I have located in over CD05 as per instructions). I wasn't convinced to start with but now the sound seems to have clicked into placed. Could the the larger value cause any problems down the line.
I note the power supply hack on your site but was slightly confused in that the photo of the regulator included several resistors and a couple of caps. Is it simply a case of adding the requisite regulator to the supply track for the DAC and using a resistor to ground to draw sufficient current or do I need to make the fancy regulator in the photo.
I'd thought about the decoder and whether to give it its own supply and also whether anyone has fed it with a "clean" clock signal.
Does anyone have a regulated supply for cd clocks etc.
Gordon
Old 23rd September 2004, 03:59 PM   #6
Default Re: Clock for CD63KI
Hi Biskit
If the clock of your choice has its own reg, I'd suggest a small transformers, some nice Schotkky barier diodes and a decent lytic, as a front end power supply for the clock (make sure it is being switched of simultaneously with the IC the clock is feeding)
However, if the clock doesn't improve the situation when fed from one of the players' supplies, I wouldn't invest more in an additional supply
succes
Guido Tent
www.Tentlabs.com
Old 23rd September 2004, 04:17 PM   #7
Thanks Guido, I was hoping you’d join the fray.
Informative as ever and wise words. I think I've got to try the clock as it will always nag at the back of my mind what I am missing and is another one to tick off the list of the seemingly endless tweaks you can do.
For what its worth I have also damped the underside of the tray and mechanism wherever possible with clear resin. I wanted something that was more in tune with the plastic, if that makes sense. I also used the resin to fill the original feet.
I am lucky in that I have another 63 that I can practise on, I mullered that one having exploded a cap or two. But it’s useful for spares and trying out tweaks.
I would highly recommend Martin's tweak for the display. I managed to get a switch, which fitted the headphone socket. Looks good and the wife and kids can switch it back on easily. I also remove most of the gold lettering form the front
Gordon
Old 23rd September 2004, 04:53 PM   #8
The regulator in the photo was an LM317T, set to give 5V. The 317s have significantly better performance than a basic 7805. If you do this, you'll need to cut the track that supplies the power presently and insert your new supply, or the new and existing regs will be connected together...
A small separate supply for any clock is a nice bonus, as Guido has pointed out. However it does need to startup at the same time, or ahead of the main digital supply. Therwise you'll find the disc motor spinning up / out of control, which happens when the decoder is missing the clock signal.
The 470uF cap will cause no problems long term BTW.
Old 23rd September 2004, 06:07 PM   #9
James,
I'm going to have to appear thick here (no change some would say), good job I benefit from thick skin.
Thing is, however many times I go over it I'm still not 100% what the connections are to attach the +5 volt supply for the DAC.
Rather than make an idiot of myself trying to explain how I understand it could you possibly give me a simple A-B explanation. Apologies if this is teaching granny to suck eggs.
Gordon
Old 23rd September 2004, 06:17 PM   #10
Biskit: WHICH 5V supply do you refer to? The three different supplies to the DAC or where to take the "clean" 10V to regulate to 5V?
I take that you have the service manual, right?
Cheers
Tom
Help needed with Marantz cd63ki not recognising discs mercedesjenz Digital Source 1 18th October 2008 02:12 PM
Marantz CD63KI - XO clock in, sound bad... Zombie Digital Source 30 2nd April 2008 08:02 PM
Marantz CD63KI Not Recognising CDs dlflclhl Digital Source 20 15th September 2006 01:11 PM
Marantz CD63KI Biskit Digital Source 0 21st June 2004 10:31 AM
Crackling/static noise from CD63ki SimontY Digital Source 5 3rd August 2003 10:23 PM
Page generated in 0.14142 seconds (84.24% PHP - 15.76% MySQL) with 10 queries
