Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
My tda1543 based dac (as if there where not enough of them around ;o)
Old 21st September 2004, 09:24 PM   #1
hifi is offline hifi  Sweden
Default My tda1543 based dac (as if there where not enough of them around ;o)
well, here it is folks.
/ Mikael
Old 21st September 2004, 10:01 PM   #2
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Any further detail?
Cheers
Andrea
Old 22nd September 2004, 10:01 PM   #3
hmm
CLC input filter and LM317 pre regs
Scientific conversion input transformer, Mcap Supremes on the output. the rest of the parts are and the parts are Holco/Rikens/cerafines/nichicon muse.
Pass transistors with TL431 regulators on the cs reciever and reclocking circuits On the Tda i have a version of Elso Kwak:s old regulator but with a reference witch gives it about 8V
The reclocking is done with a 74vhc4040 and a Tent oscillator I am aware of the weakness with this approach and someday soon I will get around to measure the jitter but it do work and resonable well at that.
/ Mikael
Old 22nd September 2004, 11:42 PM   #4
rfbrw is offline rfbrw
Why the TDA1543?
Old 23rd September 2004, 07:44 PM   #5
Why?..why not the TDA1543 ?
/ Mikael
Old 23rd September 2004, 07:52 PM   #6
/ Mikael
There are considerably better DACs around.
Old 24th September 2004, 09:05 AM   #7
sparkle is offline sparkle
sparkle's Avatar
hmm
/ Mikael
any ideas how MCap's are working in here- did You made any substitutions to determine if they are good in Your dac.
I am asking this because I have a problem- I must put some GOOD caps (like maybe mcap's) but they are expensive for me to make a mistake if they don't work in there good enough- I have tried BG's (not good enough), some very old aluminium PiO's (to sharp), some polyprop's (well some might work but which one); finally I have settled on Wondercap Ultima with Danor (very old units also but they work very good---- unfortunatelly I cant buy them new so I must find something to put in it - I can buy Mcap's in my country but they cost . Also I am thinking about some MIT Multicaps RTX or PPsomething (PPFXS I think)......
Opinions......... please
btw; dac looks very nice _suggestion; separate your dac from the power supply - or at least put some copper plates on Your CSxxxx/TDAxxxx chips.
best regards
daniel
Old 24th September 2004, 01:13 PM   #8
Hello,
Im sorry, I have no reference regarding the caps you mention so I cant really give you an objective opinion on how they would fare against the Supremes. I can however say I do enjoy those caps.
/ Mikael
Old 24th September 2004, 03:48 PM   #9
kittaylor is offline kittaylor
The best cap I've tried on my passive TDA1543 dac is a 220uf OSCON, 10v Sanyo G-type.
Old 24th September 2004, 06:35 PM   #10
sparkle's Avatar
Hifi- to bad- well, a friend gave me some normal polyprop's from MCap- will try them (he said that they are a little soft but good). Also, if I like them than I would convert to Z foil (to my knowledge a little more detailed and opened when compared to normal MCap). The supreme's are a little bit sharp (to my knowledge).
I didn't try them so I have said that only what I know from my friend - he tried them all but can't give me none except those normal- so I guess that I would discover that for myself...
Didn't tried Oscons at the output but in my analog power supply they didn't work nice (oscon SH)- I use them in digital part of the dac.... O.k. - maybe they would work at the output
thanks for the informations
best regards
daniel
My tda1543 based dac (as if there where not enough of them around ;o)Hide this!Advertise here!
Differential TDA1543 based NOS DAC dsavitsk Digital Line Level 0 6th April 2009 07:41 PM
My TDA1543 DAC based on P. Daniel Design Algar_emi Digital Source 8 11th March 2006 03:12 AM
Looking for an active I/V stage for TDA1543-based DAC IpsilonSound Digital Source 21 17th June 2004 09:34 PM
tube buffer for TDA1543 based dac sparkle Tubes / Valves 11 25th February 2004 09:24 PM
grounds in TDA1543 based dac sparkle Digital Source 7 15th January 2004 08:54 PM
Copyright ©1999-2017 diyAudio
