Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd September 2004, 07:11 PM   #1
OliverD is offline OliverD  Germany
OliverD's Avatar
Thumbs down Why Philips CD 723 is a bad base for modding
Recently I aquired a low-cost Philips CD 723 player. I paid around 40 Euros including shipping.
It is a very low cost device, but it can read CD-RW without problems. My initial plan was to refit a new power supply, clock and internal DAC which would be fed directly by the player's I2S. Going non-OS, I figured it would be a very good sound for little money project.
Here's why it won't work as intended:
The CD 723 uses a one-chip servo/decoder/digital filter solution which belongs to the CD7 family from Philips. This chip features an internal digital filter, oversampling to either 2fs or 4fs. You can chose between those two filters by software, but you cannot disable them. So no non-OS unless you use the chip's biphase-mark output.
The other problem is the digital filter in the SAA7378 is mediocre at best. The internal resolution is not sufficient at all, stop-band attenuation is very poor, and a -0.5dB downscaling is applied on all input signals to prevent overflows. The chip doesn't even dither before this downscaling. Thus, you will never get accurate samples from the CD out the I2S of the chip!
So, don't buy CD 723, although it is recommended in several threads in this forum!
Old 2nd September 2004, 08:40 PM   #2
True, but if you had search the forum, you would jave known that before you bought it.
Still, I do recommend the CD723, because it is cheap, it's a simple design, it's easy to modify.
Your problem (and only 1 problem) is that your limmit your self to the I2S output. Don't use it. But by now, you know that too. Use the S/PDIF. If you worry about jitter: use a low jitter clock near you favorite DAC and slave it through to the player... that's the ultimate solution, for any player.
Good luck,
CD723, still highly recommended!
Old 2nd September 2004, 09:08 PM   #3
OliverD's Avatar
Sometimes I do things without asking first
The -0.5dB scaling still applies, even when you use the S/PDIF. It is done in a very mediocre way, without dither and - of course - asymmetric around digital zero. It affects sound quality and prevents you from getting the exact sample values (as on the CD) out of the decoder chip.
Thus, I really cannot recommend CD 723 and similar players using the SAA7378.
Old 2nd September 2004, 09:12 PM   #4
aparatusonitus's Avatar
[i]
CD723, still highly recommended! [/B]
Particularly if you use dig. output from SAA7378 to feed 4xTDA1543A!!!
Old 2nd September 2004, 09:25 PM   #5
OliverD's Avatar
Sure sounds better than most CD thingies you can buy, but you'd be closer to audiophile heaven if you did that mod to a different player which doesn't corrupt the digital data.
That's all my post was about.
Old 2nd September 2004, 09:40 PM   #6
00940 is offline 00940  Belgium
This website (it's not mine) explains how to hack the controller to get 1fs dataflow. http://www.ifrance.com/robinetron/cd723/hack/hack.html
Sorry it's in french.
Old 2nd September 2004, 10:04 PM   #7
If that's true, it's new for me and indeed something to consider.
Could you explain it a little more ellaborate.. howcome that the S/PDIF is affected? assymetric attenuation around zero? What's that?
Thijs
Old 2nd September 2004, 10:26 PM   #8
OliverD's Avatar
Although I can't read french, I understood he is using an Atmel controller to interfere with the communication between the SAA7378 and the player's controller to alter the output format setting.
In the SAA7378 datasheet from 1995, page 15, there is a table which shows six modes the DAC output interface can work in. All of them are either 4fs or 2fs. However, in his program, is he using none of these documented modes, but rather an "invalid" combination of bits.
Now there are two possibilities:
1. This guy is really clever and remembered the SAA7378 is basically an advanced SAA7345 and a TDA1301T on one die, and the "old" 1fs modes from the SAA7345 still work in the SAA7378, although they don't appear in the datasheet.
2. He took the output format codes from a website or from a different data sheet (like the one for SAA7345), assumed they are the same for the newer chip and tried them. They don't work and the chip remains in its default setting, which is 4fs.
From looking at his website, he seems to be very knowledgeable, so I hope it's the first possibility.
It seems the downscaling multiplier is before the biphase-mark output in the SAA7378 block diagram.
This guy really had a close look at the issue and he explains it much better than I could.
It looks like my warning finally can be refuted (which is in my best interest, after all I own one of those machines), but some issues need to be sorted out before I agree:
- Can we really circumvent the digital filter section of the SAA7378 for exact bit-for-bit accuracy, by setting the output to this undocumented, "illegal" mode?
- Is there a way of disabling the mediocre -0.5db downscaling?
Old 3rd September 2004, 01:03 AM   #9
jkeny is offline jkeny  Ireland
Banned
Excellent find - I knew somebody would program a microcontroller for the CD400 (CD723) someday - I and others looked at this about a year ago and realised the SA7378 could be changed to no oversampling mode but only by sending signals to it from a microcontroller.
Looks like this is what this guy did it - ther is a lot of activity in France on this player in the site http://forums.delphiforums.com/HAUTE_FIDELITE/start
but mostly in French.
Unfortunately my French is not up to par
PeuFeu has an interest and is himself a French speaker i believe maybe he will let us know the translation.
In the meantime I sent robinetron an email to get details in english - will post them here.
Now to clear up the final
Old 3rd September 2004, 01:19 AM   #10
Banned
If that's true, that player used as a transport with an HDCD external DAC will never play in HDCD mode.
Philips CD880 disc clamp base eboy2003 Digital Source 6 21st July 2009 03:28 PM
NIB NOS GZ34 Philips EC8010 Siemens 6v6 RCA Brown Base EF86 Mullard guglielmope Swap Meet 1 24th May 2009 09:10 PM
Philips clone worth modding? S.Spielbergo Digital Source 4 1st April 2008 08:57 PM
Philips DVP 3005 DVD player modding jkeny Digital Source 1 25th February 2006 09:27 PM
Page generated in 0.13242 seconds (81.99% PHP - 18.01% MySQL) with 11 queries
