Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 27th August 2004, 12:22 PM   #1
Default DTS and Dolby Digital
am starting to build my first multichannel amp. The problem is that I need a Dolby Digital, DTS and the others' processor. Does anyone know where I can get my hands on this?
I want to start from the D/A-converters and work my way to the speakers, don't want to start writing decompression algoritms for the DTS etc. code.
Very greatful for any input.
Niklas
Old 27th August 2004, 04:46 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Buy a cheap receiver pull outthe decoder boards. The decoder-IC's are impossible to buy in small quantities since they require that you pay royalties to Dolby/DTS
/U.
Old 27th August 2004, 05:23 PM   #3
markp is offline markp  United States
I bought a JVC receiver with preamp outputs on it for use as a decoder. It's the only way to go! As was said earlier, you cant just buy the chips and use them without paying royalties that cost more than the whole receiver I bought. Not only that but you get all the other stuff like a tuner and phono pre. You also get remote controlled volume which is a nice thing.
If it sounds good... it is good!
Old 27th August 2004, 05:42 PM   #4
thanks for the info. The problem that I have (in my head) is that I don't believe that the preamp and other stuff in a cheap amplifier are good enough (let me know if I am wrong). What I wanted to do is to start off with a digital board, interface it to a microprocessor and build all the things around it with extremely good components etc. things that can not be utilized in a commercial amplifier.
I do electronics design (digital and RF) on a constant basis at work so building the digital interface (with LCD, remote etc) should not be a problem. Once I am finished with this I'll make all of it available at some site.
Thanks again for any comments,
Niklas
Old 27th August 2004, 07:49 PM   #5
The whole Dolby circuit is digital until the final D/A which is 24 bit so it sounds ok. If you want, just gut the receivers analog section and use your own. Maybe bypass the powersupply caps and that sort of thing to pooge it. I have not had time to do it yet but I will get to it soon.
Old 27th August 2004, 08:40 PM   #6
SQ Kid is offline SQ Kid  United States
Send a message via AIM to SQ Kid Send a message via MSN to SQ Kid Send a message via Yahoo to SQ Kid
out of curiousity, what jvc model did you use and how much was it?
another option a lot of people do is buying a strictly dts/dd decoder. i believe a lot of people have used the technics models with good results. also look into creative's new pc setup. it does dts and dd IIRC.
i've been looking for this kinda thing for a while. i found a few inexpensive decoders, but nothing sold in the us (the jazz de-005 is one ive been looking for for a loooong time).
Old 27th August 2004, 09:45 PM   #7
I used a RX-8030VBK that I got for $279 new not refurbed. I use my self built and designed amps for the front, center and sub and use the receivers built in amps for the rear and surround channels. It has DTS ES and DD EX so you can have up to 7.1 channels. The gain and delay are adjustable for all channels and it is done in the digital domain. It will also upconvert your digital signals to DVD data and bit rates(ie 48khz goes to 192khz). The built in amps are good enough for surround duty but not close to high-end. They claim 130wpc but I wouldnt call it that. Hey, for $279 its a steal! It was one of the few units that actually had pre-amp outs for all the channels.
Old 27th August 2004, 09:48 PM   #8
I tried looking for stand alone decoders but for the price it made no sense to me. I also look into Technics but the build quality was much better on the JVC.
Old 28th August 2004, 04:01 AM   #9
thomas997's Avatar
yeah thats what I plan to do as well.
Buy a decent quality DTS/DD decoder/preamp and use that as a source for the amp.
You can get cheaper ones from computer speaker sets, as they often have a decoder box and the amps are built into the subwoofer.
Cant seem to find many on ebay at the moment though
Old 30th August 2004, 04:02 PM   #10
If your source is a computer, you can decode in software. Check out http://ac3filter.sourceforge.net/ which has DirectShow filters for windows. If you use linux, then this is already supported in the Xine media player.
-Tor
PS for 5.1 Dolby Digital System WolfiS Power Supplies 7 2nd February 2007 01:18 PM
Dolby Digital..... bimbla Digital Source 3 31st March 2004 10:02 AM
Dissapointed in Dolby Digital 5.1.......... turboturk Digital Source 5 24th March 2004 05:36 PM
Dolby Digital/DTS to SP/DIF arniel Digital Source 11 22nd November 2002 01:47 PM
Page generated in 0.10501 seconds (81.52% PHP - 18.48% MySQL) with 10 queries
