| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | |
#12 |
It's quite easy- I just cut the link to pin 3 of the opamp. There's some spare holes to connect a pair of 220uF Bi Polar Blackgates in Super E style from the output of the DAc (after the 270 ohm I/V resistor) direct to the output socket. Disconnect the wires from the opamp to the output socket, put a 100K resistor across output socket.
That's it. Email me if you need further help. A tube buffer after the TDA1541 double dac is probably fine , but if your using a tube pre/power amp after that again ,I think you'll find the 844 buffer is much more neutral and ultimately natural. Tubes are great! but too many is as bad as too much SS. |
#13 | |
Pedja,
#14 |
Brilliant!
OK, what do you mean when you say "AD844 need a careful implementation"? |
#15 | |
May be this can help:
#16 |
Help what?
#17 |
What is what??
Afterall, it is a matter of taste. |
#18 |
OK cmt42001,
We will do it easy when it comes to the taste. The question for you is: after 3 common base stages you made with it, what matters in "AD844 need a careful implementation"? Do you have a slightest idea about it? |
#19 |
Pedja,
Glad that you have cool off. Personal taste is half the fun in DIY.. "use it the way it must be used...... At least, be aware of the way you use it." fits my idea of careful implementation. BTW, can you design some sort of auto compensation circuit to cater for the frequent adjusment of the 2SK170/trimpot combo? |
#20 |
Little calculation:
TDA1541A nonos ( strong even order harmonics ) + tube output stage ( strong even order harmonics ) + tube preamp ( strong even order harmonics ) _________________________________________ very musical, transparent & holographic sound |
| Non oversampling cd-94 MK1 | D.A.R.R.Y.L. | Digital Source | 5 | 1st December 2004 11:33 PM |
| TDA5141 oversampling or non-oversampling ? | Bernhard | Digital Source | 4 | 1st September 2004 11:27 AM |
| Non-Oversampling DAC | lucpes | Digital Source | 42 | 6th July 2004 04:06 AM |
| Page generated in 2.52093 seconds (4.41% PHP - 95.59% MySQL) with 11 queries |
