| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#12 |
Go to local electronics shop and buy "solder wick". Might have some other name but it's basicly a stip of thin copper wires strangled together. With the help of this and some flux you can remove most of the solder from SMD chip pins. After that you take a fine tip soldering iron and a thin needle and just slowly and carefully heat and bend the legs open. It needs a lot of patience and care not to destroy the PCB tracks....
Good luck, Ergo |
#13 |
Finally got around to repairing my CD63.
Tonitze was correct in stating that the TDA1301T was the likely culprit. Changed it out & the player is purring again. Clipped off the pins of the TDA1301T with a small plier & removed the chip. Used wick & plenty of solder to remove the pins off the pcb. Soldering was the hardest as the connections were so small. I was not sure at times whether I got the legs soldered properly. I used a small screwdriver & placed it between the pins & gave it a light twist ... if the legs moved = weren't soldered properly. I was supprised at the no. errors I made. Many legs seemed soldered perfectly but in fact the solder just gathered at the tip of the leg without attaching itself to the pcb. Thanks to everyone for their input & tips ... much appreciated! |
#14 |
My cd63 have the same problems, it won't read the disk,
so i change the lens using vam1202, it works. But during play, the sound crackles, so i change the tda1301t too. After some run-in, the player now plays perfectly. Thank all forumers for the tips. |
| Problem with Marantz CD63 - Need help | Ruach | Digital Source | 8 | 26th December 2010 07:42 PM |
| marantz cd63 digital out problem | dublin78 | Digital Source | 1 | 7th December 2007 01:34 PM |
| CD63 display problem | Chivvyp | Digital Source | 15 | 8th May 2006 06:35 PM |
| Original Marantz CD63 Audio Problem | garyjirving | Digital Source | 7 | 15th May 2005 05:07 PM |
| Marantz CD63 Power Supply Problem-Help Please! | KevinLee | Solid State | 12 | 12th September 2003 07:07 AM |
| Page generated in 0.08503 seconds (73.88% PHP - 26.12% MySQL) with 10 queries |
