Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st September 2004, 08:45 PM   #11
kafka is offline kafka  Poland
kafka's Avatar
!@$!#$#%@!#$%@#%&%&$^$ It was all the PLL1700 fault !! It works without it. Now I'm going to force PLL to work properly.
Old 22nd September 2004, 01:46 AM   #12
Default PLL1700
Hi Kafka,
I designed a similar system to the one you are discribing. BTW Check the TI site for the newer version of the PLL1700 clock gen device.
The reason to use this over connecting the SCK out from the DIR straight into the SCK in on the DAC is this limits you to only using the default oversampling rate.
Sourcing all local clocks from a centralised clock point improves jitter performance considerably. It also provides flexibility with oversampling rates, and allows the designer to maximise the performance of the system.
Good luck with it
apollyon25
Old 28th September 2004, 09:43 AM   #13
kafka's Avatar
All that work just to find out that the PLL1700 was broken. I've replaced it and the DAC works well... almost... one channel is louder then another. Resistors in the analog stage are matched to 0.1%. Where can I search for the mistake?
Need help with tubed output for PCM1793 DAC kkillebrew Tubes / Valves 17 30th May 2011 03:36 AM
PCM1793 DAC chip dublin78 Digital Line Level 0 9th June 2009 08:32 AM
TI low jitter clocks: PLL1700 Bricolo Digital Source 4 4th March 2005 05:10 AM
Dir1703 dmfraser Digital Source 13 13th December 2004 06:27 PM
dir1703 rip? rlim Digital Source 11 29th October 2004 09:17 PM
Page generated in 0.06719 seconds (69.65% PHP - 30.35% MySQL) with 11 queries
