Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st August 2004, 04:08 PM   #1
djd4n is offline djd4n  United Kingdom
Question Daisy chaining 2 PCM2902's
How would i go about daisy chaining two PCM2902's on a PCB, so as they only use one USB connection? is this possible?
I know u can daisy chain upto 127 USB devices, i'm thinking of more of a hard wired solution, if u get what i mean.
Basically i want to end up with 2 PCM2902's in a box, giving me 2 stereo in's and 2 stereo out's, but using only one USB connection.
cheers
Dan Morton
Old 1st August 2004, 06:45 PM   #2
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
If you run off to the local library and take out the december 2002 issue of Elektor, you'll find a small circuit with the PCM2902. It has analog in/out as well as toslink SPDIF inputs/outputs (could be modified to be coax quite easily). If you need more than one analog input/output a simple switch should do the trick. What exactly are you trying to build?
/U.
Old 1st August 2004, 07:31 PM   #3
I would like to build an external USB device, which will enable me to input 2 separate stereo analogue signals into my computer, manipulate them on my computer, with plugins etc. then output the manipulated signals again separately on 2 stereo analog outputs.
See attached picture.
Dan
Old 1st August 2004, 10:32 PM   #4
sorry the picture is at this link
Pic of out board device
dan
Old 2nd August 2004, 03:03 AM   #5
You need to add a USB hub, something like this:
http://www.smsc.com/main/catalog/usb2502.html
Attach one PCM2902 to each downstream PHY.
Mike
"Never confuse motion with action." B. Franklin
daisy chaining an electronic crossover qguy Subwoofers 5 14th January 2007 01:53 PM
DAISY Display Kit sebastian_s Digital Source 5 16th October 2006 09:37 AM
Harman Kardon A-401 Preamp Chaining?? LONGHAULTRUCKER Solid State 0 5th February 2005 08:03 PM
Daisy-chaining power cables ftjandra Parts 3 8th July 2004 03:46 AM
Daisy-chaining transformers Wingfeather Parts 13 13th May 2003 11:30 AM
Page generated in 0.08798 seconds (69.45% PHP - 30.55% MySQL) with 11 queries
