| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
I have a Marantz CDA 94 dac. I am planning uppgrading the crystal clock in it. I have though not found any crystal clock in it! I have a schematic (not complete) and there is no clock! Why? Is it possible to build a clock with passive components? Regards Kristian
kva |
#2 | ||||
Previously: Kuei Yang Wang
Konnichiwa,
Sayonara |
#3 | |
Here's the answer http://www.tentlabs.com/ProductEntit...AC/XO-DAC.html worlds' only true clock upgrade for external DACs cheers |
#4 |
Thank you for your answer.
Regards Kristian
kva |
#5 | |
Konnichiwa,
That said, IIRC, the DA94 actually contains a secondary, discrete "slow mode" PLL (The LHH-1000/DA12 certainly does and the DA94 is ALMOST identical in all key particulars) which is really not much worse than a VCXO (it also contains opto insulation between digital module and DAC and signal reclocking before the opto insulators), so the benefits of fitting the XO-DAC may be much less than in other DAC's, having no secondary PLL whatsoever. Given the age of the DA94 the best course would probably to start replacing all the aged and degraded electrolytic capacitors. Of course, many other DAC's can benefit drastically from a secondary PLL, for example in the form of the XO-DAC.... And applying the "link" connection goes down a further route of (potential) improvement. Sayonara |
#6 | |
Banned
Another example of commercial use without my consent of one of my ideas communicated in personal email. Really unbelievable. http://www.twindac.com/ Funny thing is I no longer use the AD1865 and the Asynchronous Reclocker, hahahaha.
#7 | |
Hi Sayonara I did not know the Marantz in such detail. In this particualr case, the designers did their job, allthough I have to note that not all SRC's are muically transparant I do not belive in optocouplers by the way. Getting the performance right (g no added jitter) os a hell of a job, and if you do the layout the correct way around, you do not need the isolators. That said, the main clock clocking the SRC ofcourse should be very good Thank you for your eleboration |
#8 | |||
Konnichiwa,
The thing is mid 1980's technology, TDA1541, SAA7220 Digitale filter, exceedingly well build, locks on 32/44.1/48KHz and has a two layer PLL, the first "fast" one in the receiver and a slow one with several seconds as timeconstant (guess from time to lock when signal applied and schematic) following that. The signal then goes to the SAA7220 Digital Filter, Loads of glue logic inbetween too and from there to a reclocker, from the second PLL clock. The main lines to the DAC then pass through Opto-Isolators (pretty good ones!), the whole thing is 16 Bit 4 times oversampling. Quote:
Sayonara |
#9 | |
Hi This sounds like a properly designed concept On the optocouplers: I sahve the experience it is easier to get the things right by layout than by using optocouplers. But maybe the commercial department wanted them in...... |
#10 |
I was just curious about how this machine would sound in NOS operation but after taking out de SAA7220 p/b and reconstruct the I2S lines.....
Listening to it reveals a noise that slowly fades into a couple of minutes of distortion free 'musical' signal .......than it changes back into noise again and complety fades. I know I can put in a CS or SAA 7210 receiver and skip the couplers but I would like to keep it as it is..... and if that is not possible I'll put in the SAA7220 again. Maybe someone has the experience and wants to enlighten me? Anton. [The thing is mid 1980's technology, TDA1541, SAA7220 Digitale filter, exceedingly well build, locks on 32/44.1/48KHz and has a two layer PLL, the first "fast" one in the receiver and a slow one with several seconds as timeconstant (guess from time to lock when signal applied and schematic) following that. The signal then goes to the SAA7220 Digital Filter, Loads of glue logic inbetween too and from there to a reclocker, from the second PLL clock. The main lines to the DAC then pass through Opto-Isolators (pretty good ones!), the whole thing is 16 Bit 4 times oversampling.] |
| Marantz CD-73 | Edo33 | Digital Source | 1 | 31st May 2011 01:19 PM |
| Marantz cd-32 | ObliVion | Digital Source | 3 | 15th July 2007 09:25 PM |
| Right speakers for Marantz PM8000 + Marantz CD67-OSE? | betto80 | Multi-Way | 2 | 24th May 2005 03:21 PM |
| Link Between Marantz CD12 and Marantz CD99 | Mesh | Digital Source | 16 | 7th November 2003 06:08 PM |
| Marantz T-1 | stigla | Tubes / Valves | 4 | 17th October 2002 01:11 PM |
| Page generated in 0.14875 seconds (81.70% PHP - 18.30% MySQL) with 10 queries |
