Paralleling up DAC chips - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd January 2013, 06:11 PM   #101
The recently DC-901 DSP unit from Accuphase employs two mono PCB DACs. Each DAC have two ESS Sabre 9018 DAC chips in parallel. http://www.accuphase.com/cat/dp-900_dc-901_e.pdf
I want to know if somebody have a schematic for paralleling multiple ESS 9018 Sabre DACs.
Old 2nd January 2013, 06:47 PM   #102
qusp is offline qusp  Australia
qusp's Avatar
there is a LOT more going on with the DC901 than a few parallel dacs, you can only set one of 2 i2c addresses with es9018, so using more than 2 dacs you need to have custom MCU. trhe DC901 uses custom FPGA for digital filter, custom FIR coefficients, FIR output not IV stage... sorry you are on your own if you want something similar to that.
besides honestly I wish you luck even exceeding the analogue capabilities of a single ES9018 DIY (it simply isnt easy to make more than -120dB THD+N count), no point paralleling them if you cannot leverage the performance of the extra dacs. with 4 x es9018, you have 64mA of current to deal with.... a single ESS dac is already wired for dual mono, left and right are completely separate with analogue references, analogue and digital ground for each L and R
dont just fall for the marketing blurb.
Old 2nd January 2013, 07:02 PM   #103
Thank you for answer, qusp.
So, I think if I use, for example, two Buffalo-IIIse DACs, each configured in mono mode, I understand it will be more than enough to obtain a very good quality from ESS 9018 chip. Didn't ?
Old 2nd January 2013, 07:12 PM   #104
qusp's Avatar
yes, or 2 x ackodac AKD12P as is my choice, or 2 x RD50
I really do recommend just starting with one though if you havent build a dac of this quality before
Paralleling AMP9 jringels Class D 0 12th February 2007 12:32 PM
Paralleling LM4780 chips? Dominick22 Chip Amps 29 26th February 2006 10:23 PM
paralleling chips odysseybmx414 Chip Amps 15 14th December 2005 06:57 PM
Paralleling Transformers metal Chip Amps 9 9th July 2004 09:02 PM
Any warnings about paralleling chips? Morse Chip Amps 13 29th March 2004 09:28 PM
Copyright 1999-2017 diyAudio
